The Include Files
    The Include Files
    Discussion, problems, etc. for the new include files.
    Jeff Farmer
    Jeff Farmer
    HS 3, HSPhone
    Jeff et al.
    Thanks for the work on the Include Files. I downloaded them last night and all of my scripts and pages seem to be working fine.
    I see that lots of work went into them.
    I like the extra features like the time in the tips window.
      for those of us wondering what they are talking about, look here
      [img]/infopop/emoticons/icon_cool.gif[/img]
      Thanks for the people contributing to this library of handy functions.
      They DO set a new standard in spartan documentation ;-) though.
      Robert's Audrey pages
      http://www.canoma.com/audrey
      http://www.canoma.com/audrey/controlpanels
        CFGuy,
        I'm not sure my includes.ini is up to date. I see some requests that don't seem to be in mine, and I dont think my setup page is right.
        Is there a chance that includes.txt is available in "generic" form?
        -System Spec------
        ASUS A7V333ARU VIA KT333 MOTHERBOARD; AMD ATHLON XP PROCESSOR 2200+ (1800MHz); 1024MB DDR 333MHz DDRAM; ATI RAGE 128 CHIPSET 32MB W/ TV OUT VGA CARD; AHANIX PLATINUM XP SILVER/BLACK COLOR 9 DRIVE BAYS SPI 300W POWER SUPPLY TOOL-LESS PANELS ATX MID TOWER CASE; Win2K SP2 5Serial 1Parallel, Hawking Modem, Broadband >Mediacomm, Phillips Audio, ATT Voices, PhoneSwitch, 10/100 Ethernet, Ocelot for IR and Bobcats, CM11A for X10
        GenevaDude
          Opps, forgot to post to the docs.
          http://www.c-website.com/securelinks5.htm
          GenevaDude
          If you have an includes.ini then you have the most current. The ini is new with this release of the includes. The idea was to allow you to set the defaults rather than me making that decision and hard coding them in.
          The ini file is in the Homeseer config directory.
          Jeff Farmer
          Jeff Farmer
          HS 3, HSPhone
            Setup_Includes.asp seems to have a problem with the first radio-button. Selecting Use Security: Yes leaves No on as well. Saving and reloading - it goes back to No.
            --Bill
              I see what is causing it. I'll fix this tonight and post it.
              Jeff Farmer
              Jeff Farmer
              HS 3, HSPhone
                I'm getting this error when loading the setup_includes.asp file:
                Script error: [Microsoft][ODBC Microsoft Access Driver] Undefined function 'GetDate' in expression.
                I checked (& double checked) the ODBC setup and it seems to be okay.
                Replaced the customhs2k.mdb with a freshly downloaded one.
                  Looks like you have SQL server set somewhere. Check in the ini file - websettings.ini and look for this line.
                  dbtype=
                  Make sure it has the value of Access
                  dbtype=Access
                  Jeff Farmer
                  Jeff Farmer
                  HS 3, HSPhone
                    I am in the process of installing the new includes. I changed the menu edit to the new one and it just spills the page at Script error: [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified.
                    I have tried to set web_settings.ini to no avail.
                    here are the lines.....
                    [Settings]
                    dbpath=c:\homeseer
                    dbname=HomeSeer_2000.mdb
                    dbusername=
                    dbpassword=
                    dbserverip=http://moo:8383
                    rowstyle=Link
                    usesecurity=True
                    linkfileext=htm
                    dbtype=access
                    hsip=
                    exthsip=v1
                    footerlinkrule=Same
                    useslideinmenu=No
                    audreyrowstyle=Image
                    fpoptimeout=20
                    fpopport=110
                    touchscreenips=
                    usesound=True
                    showhsversion=No
                    showhssystime=No
                    logpagehits=1
                    [Device Admin]
                    Device_Hide=1
                    col_Status=1
                    col_Status_Level=10
                    col_Code=1
                    col_Code_Level=10
                    col_Locations=0
                    col_Locations_Level=10
                    col_Dev_Type=0
                    col_Dev_Type_Level=10
                    col_Last_Change=1
                    col_Last_Change_Level=10
                    col_Edit=1
                    col_Edit_Level=10
                    col_Control=1
                    col_Control_Level=10
                    col_Events=0
                    col_Events_Level=10
                    col_String=0
                    col_String_Level=10
                    Device_Hide_Level=10
                    I'm sure my formatting or syntax is wrong..
                    All other older include pages still work with the settings tha are in maininclude.asp and DSNString.vbs
                    ...............JG
                    HS2PRO - Ocelot, SecuIR, Secu16, Attendence Management Alarm Interface, X-10, LCD Studio VFD Display, 3 Apexis IP Cams, Custom Software Interfaces, GMQ Geiger Graphing
                    HS3PRO - Testing
                      Bill,
                      Here is the fix for the Security setting.
                      Jeff Farmer
                      Jeff Farmer
                      HS 3, HSPhone
                        Jebus, change dbtype=access to dbtype=Access
                        Jeff Farmer
                        Jeff Farmer
                        HS 3, HSPhone
                          Jeff, that fixed it. I think I figured out how it happened. . Using a 'wheel' mouse; I was on the setup page the other day and selected that field and I must have jogged my wheel at some point and didn't notice.
                          Could you help with this error?
                          Script error: Type mismatch: 'GetDBValues'
                          I get this anytime I select any of the 'Device' links . . .
                          Also, something that is driving me crazy: Any link that I select from the "Homeseer Links" want to go to either /hs/pagename.asp or /control/pagename.asp. . . of course the pages aren't in the html/hs or html/control directories, so the links are broken. Would you point me in the right place to fix this?
                          Thank you -
                            To the the new includes to work for everyone, I moved some functions around.
                            Download http://www.c-website.com/securelinks.zip and replace any of the files that you get errors on.
                            Make sure you have put all of the new includes into the includes directory. Expecially db_functions.asp.
                            Jeff Farmer
                            Jeff Farmer
                            HS 3, HSPhone
                              For everyone reading this thread the links that cxl99 is refering to is part of Secure Links not the includes.
                              cxl99, there is an edit page for the links.
                              menu_editor.asp
                              You can either delete the links that you aren't using or you can edit them to be pointing to the correct directory for where those files are.
                              Jeff Farmer
                              Jeff Farmer
                              HS 3, HSPhone
