Basically, I've got an event which runs a script to dim the lighting in the bedroom when it is triggered.
I trigger it manually through Homeseer, and it works fine, I trigger it from an X10 Mini Timer and it works sometimes and fails others. The correct trigger always gets from the Mini Timer to Homeseer as it appears in the log, but when the event doesn't execute I get an error in the log as follows: "Error~!~Script error in file: bedroom_going_to_sleep1.txt: 0: in line 0"
I'm sure the script is fine as it works when triggered through Homeseer directly, and it used to work everytime from the Mini Timer - before I recently had to rebuild my machine after a crash, and Homeseer was re-installed.
I've run the updater to get the latest version of Homeseer, but I think I was using this version before the crash !
Help !
Help !
