I would like to modify the following script so that it will display the Linksys "on" icon when it sends the wanip.htm to the staus column.
' PostWanIP.txt
' Purpose: Retrieves WAN IP from a LinkSys router. Once the IP is retrieved,
' script will set the virtual device specified in strIpDevice to this
' address. A web page will then be created and FTP'd to the location
' specified by strFtpHost.
' Author: Brian Raynor (hraynor@sc.rr.com)
' Version: 1 for HomeSeer 1.5
' Usage: Create a recurring event (say, every 5 minutes) to execute an event
' that runs this macro. It will ensure that your IP is updated to both
' HomeSeer (in the virtual device) and an external web page.
' Note: Please modify the string constants below to your needs
const strIpDevice = "r38" ' X10 virtual device for IP address
' LinkSys router settings - must be modified to suite your router
' Please note that in general, the LinkSys does not have a username to log in with, only a password
const strRouterPage ="xxx.xxx.xxx.xxx/Status.htm" ' Page to retrieve info from. This is the factory default
const strRouterPassword = "xxxxxxxx" ' Password to login to switch
' Settings for FTPing a web page with desired information.
const strFtpHost = "web url.com" ' FTP site to place web page on
const strFtpUser = "xxxxxx" ' FTP user name
const strFtpPassword = "xxxxxxx" ' FTP password
const strFtpLocalFile = "C:\program files\homeseer\html\WanIP.htm" ' Local file to create for web page
const strFtpRemoteFile = "ip.htm" ' Destination file on web server
' Set the HomeSeer port below for the web page
const strHomeSeerWebPort = "##" ' Change this to your port, default is 80
const cStatusAllOff = 0
const cStatusOn = 2
const cStatusOff = 3
const cStatusDim = 4
Dim strBuffer
Dim strFullRouterUrl
Dim strWanIp
Sub Main()
strFullRouterUrl = "http://"""":" + strRouterPassword + "@" & strRouterPage
strBuffer = ""
strBuffer = hs.GetURL( strFullRouterUrl, "", True, 80 )
if strBuffer = "" then
' If page was empty, set Status to OFF as a flag
hs.SetDeviceStatus strIpDevice, cStatusOff
else
strBuffer = hs.StringItem( strBuffer, 3, "IP Address:" )
' Get the WAN IP address
strWanIp = hs.StringItem( strBuffer, 1, ";" )
hs.SetDeviceStatus strIpDevice, cStatusOn
hs.SetDeviceString strIpDevice, strWanIp
FtpIpWebPage( strWanIp )
end if
End Sub
Sub FtpIpWebPage( strIp )
Dim strPage
strpage = "<HTML><BR>WAN IP Address: " + strWanIP + "<BR><BR>" _
+ "<A HREF=""http://" + strIp + ":" + strHomeSeerWebPort + "/" _
+ """>Connect to HomeSeer</A></HTML>"
FtpText strPage
End Sub
Sub FtpText( strText )
Dim Folder
Dim TextStream
Dim strReturn
Set Folder = CreateObject( "Scripting.FileSystemObject" )
Set TextStream = Folder.CreateTextFile( strFtpLocalFile, True )
TextStream.Write strText
TextStream.Close
strReturn = hs.ftp( strFtpHost, _
strFtpUser, _
strFtpPassword, _
"PUT", _
"", _
strFtpLocalFile, _
strFtpRemoteFile )
if strReturn <> "" then hs.WriteLog "FTP IP Error", strReturn
End Sub
[This message was edited by Alfonso on Wed, 13 August 2003 at 05:09 PM.]
[This message was edited by Alfonso on Wed, 13 August 2003 at 05:11 PM.]
' PostWanIP.txt
const cStatusOn = 2
Dim strBuffer
Dim strWanIp
Sub Main()
strBuffer = ""
else
end if
End Sub
Dim strPage
FtpText strPage
End Sub
Dim Folder
Dim TextStream
Dim strReturn
TextStream.Close
strFtpUser, _
strFtpPassword, _
"PUT", _
"", _
strFtpLocalFile, _
strFtpRemoteFile )
End Sub
