[SCRIPT] Search your logs for errors and then email a summary to you
    William,
    nice idea for a script!
    I had a bit of a problem though...
    "Script error in file: log_check.txt: 9:Subscript out of range: '[number: 0]' in line 28"
    so altered it a bit. I also put the search terms in an array.
    Should you want to update your script in the script library, my revised code is below.
    sub main()
    'Credit for the log reading part to the author of Visitor_IP.txt
    hs.waitevents
    Dim log_line , error_list , todays_date , line_date , MyDate, SearchFor
    SearchFor = Array ("error","alarm","InFo","WhAtEVeR") 'Add as many strings as you like
    Path = hs.GetAppPath & "\ah.log"
    todays_date = CStr(Date)
    Set fso = CreateObject("Scripting.FileSystemObject")
    Set file = fso.OpenTextFile(Path, 1)
    Do Until file.AtEndOfStream
    log_line = file.ReadLine
    MyDate = Mid(log_line, 1, 10)
    If todays_date = MyDate Then
    For i = 0 to UBound(SearchFor)
    if instr(lcase(log_line),lcase(SearchFor(i))) then
    error_list = error_list & log_line & vbcrlf & " " & vbcrlf
    End If
    Next
    end if
    loop
    if error_list = "" then error_list = "No errors found in this log"
    hs.SendEmail "to@address.net","from@address.net","HomeSeer Error Summary as of " & date() & " " & time(), error_list
    file.Close
    Set file = Nothing
    Set fso = Nothing
    end sub
    This looks like a very useful script. I know it won't run under HS3/Latest VB.net. How far is it from being "repaired?"
    Enabled Plug-Ins:
