the asp page works great, but when I say what is playing at "theatername". It says executing what is playing at theatername and returns nothing back to me over the phone. What did I setup wrong, remember the asp page and update movies works fine.
movies asp page works, but will not retrieve listing via phone
No it does not play out of the soundcard to computer speakers locally, nor does it play back over the phone. You simply request for what is playing at "theatername". The text to speech engine replies, "Executing what is plaing at Venture" and then nothing comes out
via telelphone or via soundcard.
Here is some more info, If I execute the event for my theater by running test on the theater showtimes 2.txt script I get the following output..
Homeseer speaks the following output and then stops speaking
"These are the current showtimes at Venture"
then it never list showtimes
the hs log shows the following
These are the current showtimes at Venture UNKNOWN
but the interesting thing is the showtimes are populated in the movies.asp page.
Any idea why it will not speak?
David
The VR string is in the event which can be viewed from homeseer's GUI. Take a look at this string and see what information was captured as the script was run. You can also put a debug statement in movies.vbs where the VR string is being formed to better understand why it may not be as expected.
It sets devicestatus for each device t1, t2, and t3 to the movie schedule at the theater. However these device status show a lot of crazy characters. NTSB, etc
I noticed that the movies.vbs says version 3.92 while all the other script files in the update say 4.12, could this have something to do with the problem?
cool. Manually creating the devices does populate the devices with the html move status.
Is this script supposed to say via voice over the phone what movies are playing?
like I say, "what movies are playing at Venture"
and it comes back and says, "these movies are playing at GTC Theater Venture" and stops. Never giving dialog of the movies playing after that.
Is it supposed to? like I said the movie info is there on the movies.asp page.
HAve a look at your mcsMovies.ini file. What value do you have for the line:
<pre class="ip-ubbcode-code-pre">
; Set to true if VR events should be created that allow voice request for movie info
GenerateVREvents=false
</pre>
Notice mine is set to false so no VR events are created. Is your set to true?
-Rupp
Hum ... How much deeper would oceans be if sponges didn't live there?-Rupp
GenerateVREvents=true
is what I have mine set to.
The events are created, and they do respond to the "what is playing at venture" voice request by my phone. Then it comes back with, "These movies are playing a GTC Theater Venture" and stops and that is it without any movie listings sounded over the phone
sexy-trousers
Did anyone find out why the movie names and detail aren't being read back? I'm having the same problem as David...
mcouture
I to just installed this script and the webpage work great.
But the I cannot retrieve a listing from the phone. It never finishes the sentence. In the VR scripts it shows the movies populated in what can be said, however it doesn't work.
Has anyone got this feature to work?
beach
David,
Take a look at this thread:
http://ubb.homeseer.com/6/ubb.x?a=tp...3&m=8426086465
Look on the second page. Use the vr file provided by Michael, and this should solve all of your problems. I do not use the phone, however. I use a microphone, so I don't know if it will work on the phone. I know that we had a lot of problems and finally Michael worked them out. The only thing that does not work is when you have a long movie name like Lord of the Rings: Return of the King. For some reason the vr cannot understand it. Otherwise, every other feature works! It's great!
