Can scripts be edited remotely?
    I was wondering if there is a script out there that will allow remote editing of scripts. For example, if I am away from my computer, at another location, I would like to be able to modify or even add scripts to my homeseer. Thanks.
    Using the Events View in the HS web interface and then select the Scripts text under the action heading.
    -Rupp
    -Rupp
      As for adding scripts... You can only edit scripts currently in your 'scripts' folder.
      I use an FTP server to make remote changes in my HomeSeer directory.
      I use WarFTP. It's free and right here...
      http://support.jgaa.com/index.php?MenuPage=download
      Jim
        You can add new scripts also.
        Go to the scripts tab for an event.
        Type the name you want for a new script.
        Click Submit Selection.
        Enter your script in the textarea.
        Click Save Script.
        This will create the script file in the scripts directory.
        You can also use the Plugin Message Server to edit and create new scripts from a remote client. Message Server actually allows you to edit scripts and web pages both.
        Jeff Farmer
        HomeSeer user since March, 2000
        Wiring Wall
        HomeSeer
        Jeff Farmer
        HS 3, HSPhone
          <BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>You can add new scripts also.
          Click Save Script. <HR></BLOCKQUOTE>
          Don't know what I was thinking... : )
          It is handy to be able to FTP other files however.
          Jim
            If you use Christian's MS_Client, it has ability to access the entire Homeseer directory and a built-in text editor to modify any scripts.
            Simon
