Can scripts be edited remotely?
  • Guest's Avatar
    Guest replied
    If you use Christian's MS_Client, it has ability to access the entire Homeseer directory and a built-in text editor to modify any scripts.
    Simon
  • Jroberts
    <BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>You can add new scripts also.
    Go to the scripts tab for an event.
    Type the name you want for a new script.
    Click Submit Selection.
    Enter your script in the textarea.
    Click Save Script. <HR></BLOCKQUOTE>
    Don't know what I was thinking... : )
    It is handy to be able to FTP other files however.
    Jim
  • CFGuy
    Click Save Script.
    This will create the script file in the scripts directory.
    You can also use the Plugin Message Server to edit and create new scripts from a remote client. Message Server actually allows you to edit scripts and web pages both.
    Jeff Farmer
    HomeSeer user since March, 2000
    Wiring Wall
    HomeSeer
  • Jroberts
    As for adding scripts... You can only edit scripts currently in your 'scripts' folder.
    I use an FTP server to make remote changes in my HomeSeer directory.
    I use WarFTP. It's free and right here...
    http://support.jgaa.com/index.php?MenuPage=download
    Jim
  • Rupp
    Using the Events View in the HS web interface and then select the Scripts text under the action heading.
    -Rupp
  • Guest's Avatar
    Guest started a topic Can scripts be edited remotely?
    I was wondering if there is a script out there that will allow remote editing of scripts. For example, if I am away from my computer, at another location, I would like to be able to modify or even add scripts to my homeseer. Thanks.
