D-Link DI-604 IP checker Script
    Does any one have a script that gets the IP from the dlink status page and displays it in a Virtual device?
    Here is what the page looks like hope this works
    HS2 Environment
    Zotac 1.83 GHz Quadcore
    HomeSeer Way2Call
    Netiom-Xap board
    opnode 1-wire 1.2.7
    Plug-In's
    WeatherXML 1.0.0.32
    Pwr Link USB 1.0.0.13
    mcsTemp V6.2.0.14
    mcsXap V3.0.0.0/3.0.0.20
    IM Connector 4.87.2.5
    Sip Connector 2.56.2.4
    RFXCOM 15.0.0.22
    Odroid X2
    Asterisk 11.5.1
    FreePBX 2.11.0.42
    WebMin 1.720
    Xap Switchboard by Mi4
    There is no place Like 127.0.0.1
    Hometech,
    I assume you want your WAN IPAddress correct? If so it should be fairly simple to set up a page to "scrape" it.
    Or even easier use the script I posted here to get it for you and post it as a virtual device as well as email you if it changes:
    http://ubb.homeseer.com/eve/ubb.x?a=...976#5822997976
    -Rupp
      Thanks Rupp! I will give it a try . I had a script called Get_WAN_IP.vbs from Tom Kern that checked two sources www.my-ip-address.com & http://checkip.dyndns.org one site has a pop up on it although both seem to show the ip I get this message:
      4/11/2004 7:30:27 AM~!~Get_WAN_IP.vbs~!~Checking alternate source for IP info...
      4/11/2004 7:30:28 AM~!~Get_WAN_IP.vbs~!~IP Confirmed from http://www.my-ip-address.com
      4/11/2004 7:30:28 AM~!~Get_WAN_IP.vbs~!~Problem obtaining new IP Address from http://checkip.dyndns.org
      4/11/2004 7:30:28 AM~!~Get_WAN_IP.vbs~!~Could not resolve current IP address from any sources!
      so I was looking for a source that would not change like the D-link page. If any one has one for dlink or had a fix for Tom script ver 07.15.03 let me know
      Thanks All!
      HS2 Environment
      HomeSeer Way2Call
      Netiom-Xap board
      opnode 1-wire 1.2.7
      Plug-In's
      WeatherXML 1.0.0.32
      mcsTemp V6.2.0.14
      RFXCOM 15.0.0.22
      Odroid X2
      Asterisk 11.5.1
      FreePBX 2.11.0.42
      WebMin 1.720
