I made a small change in the FormatForecastStringHTML function to make the date formatting in the forecast more consistent. I was getting stray chars at the end of the day.
When I made the same change to the script, I lost the month. So I took a look at my regional settings and changed to match dddd, MMMM dd, yyyy and it worked. My origianl setting was, ddd, mmm dd, yyyy, which does not appear to be a standard setting. I must have changed it for a reason, oh well not sure why now.
I have also noticed some problems with the current condition icon. In the XML file it refers to the MSNBC site, and I assummed that the data was coming from MSNBC. Earlier this moring the condition icon was a Sun from the XML and Moon on the MSNBC site. Have you seen this as well?
I may send them an email and see if I can get clarification.
Rick - After fixing the date, I thought I'd go to the site itself to see what data was being parsed. I entered the info for Cherry Hill NJ, and got a different set of data than what is being displayed. For example:
Conditions: Script says "Mostly Sunny", site say "Mostly Cloudy".
Wind: Script says "13 MPH", site says "18 MPH"
Same with the other values. My settings.ini [location] shows Cherry Hill as the city, NJ as the state, and 08003 as the zip. All correct.
(I'd also like to change the Texas flag to NJ - what site did you get the icon from?)
I have noticed these irregularities as well. I am going to send an email to confirm a few things. In the XML it indicates when the update occurred, I seen update time earlier than the current time. Hopefully I can get some info from them.
Is there anyway you could make a separate ini file for this script. This way if I decide not to keep using this or any other script it doesn't leave information behind in my HS ini file.
-Rupp
...One Nation Under GOD, Indivisible, With Liberty And Justice For All.
I noticed on the forecast (Westport, CT) that each day had some porton of the end of the day repeated. I copied it for you to see below but first noticed it when Agent was speaking the forecast:
Sunday
y, December 01, 2002
High: 36°
Low: 22°
Condition: Windy
Precipitation: 0%
Monday
y, December 02, 2002
High: 38°
Low: 20°
Condition: Flurries
Precipitation: 30%
Tuesday
ay, December 03, 2002
High: 36°
Low: 20°
Condition: Partly Cloudy
Precipitation: 0%
Wednesday
sday, December 04, 2002
High: 34°
Low: 23°
Condition: Cloudy
Precipitation: 20%
Thursday
day, December 05, 2002
High: 38°
Low: 19°
Condition: Flurries
Precipitation: 30%
Just installed this script, worked fine out of the box, apart from:
1) Here in the UK, we use dd/mm/yy as our date format. How do I change this in the script?
2) 'Updated' times are given in EST. Again, GMT is our flavo(u)r - can I change this too?
Otherwise, great job! I got totally peed off with weather.com changing their html every few days and messing up my settings. Hopefully this should sort things...
So simply remarked out the second 'tempdate=' line and I get the full date as required. The only problem is it's still reading days as months, as you can see from this screengrab...
