Rover for pocket PC cannot turn on X10 any thing
    This is going to sound strange but I am using rover the latest ver off the update page. I can access it on my Ipaq . If a light is all ready on I can turn it off BUT I can not turn on X10 any thing. When I look in HS it shows that the device is on but it is not for real. I can control the all X10 device from HS without a problem. so I am at a loss to understand Y this does not work. Any thing I should check ?
    HS2 Environment
    Zotac 1.83 GHz Quadcore
    HomeSeer Way2Call
    Netiom-Xap board
    opnode 1-wire 1.2.7
    Plug-In's
    WeatherXML 1.0.0.32
    Pwr Link USB 1.0.0.13
    mcsTemp V6.2.0.14
    mcsXap V3.0.0.0/3.0.0.20
    IM Connector 4.87.2.5
    Sip Connector 2.56.2.4
    RFXCOM 15.0.0.22
    Odroid X2
    Asterisk 11.5.1
    FreePBX 2.11.0.42
    WebMin 1.720
    Xap Switchboard by Mi4
    There is no place Like 127.0.0.1
    Any errors in the HS log file?
    -Rupp
      No that's strange in the log it looks like rover did turn on the living room light but it did not. Is there some login user name / Password that needs to be entered for HS to prosses it? may be I am in guest mode?
      HS2 Environment
      HomeSeer Way2Call
      Netiom-Xap board
      opnode 1-wire 1.2.7
      Plug-In's
      WeatherXML 1.0.0.32
      mcsTemp V6.2.0.14
      RFXCOM 15.0.0.22
      Odroid X2
      Asterisk 11.5.1
      FreePBX 2.11.0.42
      WebMin 1.720
        Hometech,
        If you can in-fact control the light/lights in question from the HS gui but not Rover then I would shoot an Email to Hunter first and make sure it doesn't require a login. Then I would submit a help request with this problem. I have a problem with a device that is in a list of lights to be turned on at night and the exact same thing happens. All of the lights in the event come on except for one. If I attempt to turn on this one light (using a palm pad remote) it will not come on. If I turn it off and then on it works every time. It's as though HS thinks it's in a smart group but it's not.
        -Rupp
          Yes that is correct I can control through HS Gui
          but not rover. The only thing I can do with Rover interface is turn off an X10 device that is all ready on. I know it sounds strange. In the hs log it shows that it turned it on and and in the gui the light bulb is on . But not in real life in the room. I can control everything in the house with out a problem from HS dirrectly. Ok I will do as suggested and email Hunter. I was hoping that it was something stupid I did. Thanks Rupp!
          HS2 Environment
          HomeSeer Way2Call
          Netiom-Xap board
          opnode 1-wire 1.2.7
          Plug-In's
          WeatherXML 1.0.0.32
          mcsTemp V6.2.0.14
          RFXCOM 15.0.0.22
          Odroid X2
          Asterisk 11.5.1
          FreePBX 2.11.0.42
          WebMin 1.720
            That's strange. I use rover all the time, although not from a pocket PC, but from an Audrey, and from a side panel in Opera (web browser) and it works fine in both.
              I will let you know what it ends up being. Maybe its the operator ? we will see.
              Thanks all
              HS2 Environment
              HomeSeer Way2Call
              Netiom-Xap board
              opnode 1-wire 1.2.7
              Plug-In's
              WeatherXML 1.0.0.32
              mcsTemp V6.2.0.14
              RFXCOM 15.0.0.22
              Odroid X2
              Asterisk 11.5.1
              FreePBX 2.11.0.42
              WebMin 1.720
                Rover needs some updates
                I think this is because of the way Rover handles dimming. There was a new command added to HomeSeer in a later version of 1.7 that I'd been asking for for years, that would fix this -- but by that time, I had dropped out of developing and maintaining Rover and was barely even using HA. I'll be getting Rover up to current specs soon as I get my new system up.
                News, support, and updates for Rover, Network Monitor, TimeIcons, and more
