Look in your local copy of the windows script documentation regarding FSO (filesystemobject). Within the sample code is exactly what you are looking for. The attached may not work 100% as is, but has the items you asked about.
<pre class="ip-ubbcode-code-pre">
Dim FSO
Dim TestFilePath
TestFilePath = "C:\somepath\somesubfolder"
Set FSO = CreateObject("Scripting.FileSystemObject")
If FSO.FolderExists(TestFilePath) Then
' path already exists
else
Set TestFolder = FSO.CreateFolder(TestFilePath)
end if
Set SubFolders = TestFolder.SubFolders
Set SubFolder = SubFolders.Add("Beatles")
</pre>
