Check if date is a holiday
    Here are the 2 things I tried.
    The one like the image above and the "Copy" one I tried to integrate part of the old bjd-read calendar script.
    Tim
    FB Page - https://www.facebook.com/pages/Capt-Tim/209398425902188
    HSTouch Layouts - https://www.facebook.com/media/set/?...5902188&type=3
      I am using Jon00's HTML2Img script to capture the cal.asp page from HS3.
      I have tried editing the cal.css and cal2.css files with no luck.
      When the screen is captured it shows white lines between each date box and looks funny in HSTouch, because my backgrounds are black.
      In the HS3 browser the white lines are not there.
      Any ideas?
      Tim
        Here it is in HS3.
        Tim
          Anyone?
          Tim
            Is anyone having trouble with the month of December rendering in the HS3 web page?
            I just get a bunch of code. Then i scrolled down alittle, got the first 10 days showing, then just a bunch of code again.
            I went to the "Next Month", "Previous Month" buttons and they look fine.
            Just December is messed up.
            Tim
              At the top of the page it says - Script error: Type mismatch: 'CBool'
              Just tried "Previous year" and "Next Year" buttons they do the same thing, but only for December.
              Tim
                Fixed it.
                Went through the files a dozen times.
                It was a bad entry in the "isholiday.ini" file.
                Tim
                  Problem with Object reference
                  Hi!
                  Having a severe cold which keeps me from paid work I can spend time to fix one thing I have wanted for a long time - exceptions for holidays in events! I tried creating my own scripts earlier without success but now found Sparkmans scripts that looks to be exactly what I need.
                  I have
                  * extracted files and putted them in place in the HS directory structure
                  * edited isholiday.ini to hold swedish holidays and with swedish names for weekdays and months
                  Unfortunately I get an error (or rather "warning") when I trigger isholidaytoday.vb;
                  Warning - VB.Net script exception(0), re-starting: Objektreferensen har inte angetts till en instans av ett objekt
                  (translated to English: Object reference not set to an instance of an object)
                  Are there an easy explanation - did I miss something else I need to do - maybe some virtual devices need to be created first? Or is it possible to force a more detailed error output?
                  Regards
                  Fredrik
                    Originally posted by sparkman View Post
                    Hi Jim, I'm not sure as I've never tested it on linux or heard from others whether it works. I'll check the code tonight to see if there's anything that would prevent it from running on linux. I'm not sure if the asp web pages are supported under linux. Maybe give it a try and let me know what, if any, errors you get.
                    Cheers
                    Al
                    Hi Al,
                    I hate to bring up such an old thread, but I've been struggling to get this to run on the HS3Pi (Linux). I have your 5.0 VB code running just fine on Windows but the Pi doesn't seem to like some fundamentals such as "Includes" and "FileSystemObject". Did you ever have a chance to get this working on Linux?
                    TIA,
                    Mitch
                    http://www.midondesign.com
                      TTT
                      Hope something like this is incorporated into HS4 (most likely not)... so hope this script or another plugin will make it in!
                        Originally posted by Midon View Post
                        Hi Al,
                        TIA,
                        Mitch
                        Sorry Mitch, missed your post. I haven't made many updates to these scripts for quite a while. I do plan on integrating it with BLGData so that the data in here can be seen on calendars on our phones. However, it's been relatively low on my priority list and will likely delay this till after HS4 is released to see if it requires further modifications. I'll see if I can eliminate non-linux supported calls but I have limited ability to test on linux at this time, but will see what I can do. Most of it was written during HS2 days using ASP which is not supported on linux as far as I understand.
                        Cheers
                        Al
                          Originally posted by TeleFragger View Post
                          TTT
                          I plan to keep this working under HS4 assuming there are few issues with that.
