Comments, questions or suggestions on the Maxi Controller keypad script.
I have just updated and posted to the script library the awaited version of my X10 Maxi controller command and event manager script.
This script allows you to enter a combination of unit codes from an X10 16 unit-code Maxi controller and then take action on the resultant code. You can either trigger an HS event, launch an HS script, directly control an HS X10 device by address or name or speak a predefined phrase.
Full documentation is in the script library and install documentation is in the zip archive.
As always, any questions, comments or suggestions for improvements are greatly appreciated.
George
[This message was edited by George Photakis on Sun, 15 June 2003 at 08:51 PM.]
George
