View And Manage HomeSeer Devices With "Voice command" Enabled Setting
    #16
    Originally posted by dbrunt View Post
    For HS4 4.0.6.0...
    Clarification: this is for Linux. Not required on Windows HS3. Not tested on Windows HS4 AFAIK.
      #17
      Is I possible to have the same aspx work in Windows AND Linux? Or are separate aspx's required...
      HS4 Pro Edition 4.1.10.0 (Linux - Debian 10) running on Lenovo ThinkCenter
      Plugins: Z-Wave
      HA 2020.12.1 running on HP ProDesk
      Add-ons: AccuWeather, Adaptive Lighting, Alexa Media Player, COVID-19, Geofency, Google Cast, HACS, Insteon, IPP, Life360, Local IP, Logitech Harmony Hub, Mobile App, MQTT, Nest, OpenWeather, OpenZWave, SpeedTest, Ubiquiti UniFi, Zigbee
      Integrations: AppDaemon, Duck DNS, Entiry Controller, File Editor, Google Drive Backup, Home Panel, Mosquitto, NGINX SSL Proxy, Samba, TasmoAdmin, Terminal SSH, motionEye
      OpenZWave 1.6 running on RPi3B+ with RaZberry controller
        #18
        Yes, the version with the two additional lines works on Windows as well.
          #19
          Jean, if you're comfortable with this, perhaps you could modify your attachment in post #1 with the new modified aspx?
          Plugins: Z-Wave
            #20
            Sure, I will make the needed edits later today.
            Jean-Marie G. Vaneskahian
            jean@vaneskahian.com
              #21
              man i wish i could get hs4 to add to google..i cant get it too... and its the only thing im missing in hs4... ill have to still check this out after you update it
                #22
                Originally posted by TeleFragger View Post
                man i wish i could get hs4 to add to google..i cant get it too... and its the only thing I'm missing in hs4... ill have to still check this out after you update it
                I suspect the Google integration works similarly to their Alexa skill? I had to contact HS Support and have them fix my account on their end as the migration from 3 to 4 did not setup/migrate HS3 license to HS4 license and correctly do whatever it needs to do to setup in their back end (something like that). HS4 worked. MyHS worked. Alexa did not... Also, hopefully know that if you have any bad (i.e. alexa/google does not like them) voice enabled devices or events it will cause the whole discovery process to fail, at least for alexa...
                PS You don't have to wait for him to update it. Go ahead and download the original version and then edit these two lines into the beginning of the file:
                <%@ Import Namespace="System.Collections.Generic" %>
                <%@ Import Namespace="System.Linq" %>
                Plugins: Z-Wave
                  #23
                  Download link missing?
