Solar Position Script
Thanks for this, sparkman ! I've been meaning to write this script for ages. I found the page you found, and started the cleanup.
Luckily I found your script when I was looking for som e of those constants, so it saved me the work!HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Running on Windows 10 (64) virtualized on ESXi (Fujitsu Primergy TX150 S8).
I am planning on using it with this device https://www.switch-bot.com for curtains that I have on a pole rode in my living room. I have a baby grand piano fairly close to the south facing window which we have to close the curtains to keep the heat of the sun off. Been thinking for quite some time how to automate but just found this device lately which may be my solution. There's an api apparently available... looking into it now...
RobertHS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
And now I'm stumbling in, finding this. Nice. Seems to be calculating things right for me here in MD.
What're some thoughts on tying this with live luminance data?
I have some shades in the home office that are battery operated. Hunter Douglas, with bi-directional opening (top/down & bottom/up). I have them on scheduled open/close cycles and that's good for average days. But on overcast days it'd be nice to let in more light. The problem is during winter months, the low angle is bad for opening the bottom (shines in the eyes). But for summer it's the opposite, the sun being high in the sky means letting the top open is a problem.
I want to avoid twitching the shades too often, as it'd be annoying and waste battery life.
Any thoughts on the 'logic tree' to use for this?
I have the UltraRachio plug-in, and that has several weather-related values. Their current cloud cover value is largely unsuitable for shade management. I don't know how they determine it, but what it thinks is 'cloud cover' is nothing like what we have here on-site. Not unexpected though as that's not why they provide the data. They do have some 'weather conditions' fields that could be useful. An integer for various conditions and I could use that in conjunction with a live luminance value from an outdoor sensor.
I'm thinking, is the room occupied, is it daytime, is the outside light below a certain value, and is it forecast for "not sunny".
That would cover me for the baseline, the next branch would be to factor the solar data. Low/high winter/summer, and then use that to trigger a shade scene.
Sound about right? Any gotchas to consider?
I have a luimnance detector in room with shades....
run script after sunrise and before sunset, every 15 mins.....and luminance is greater than certain value.
Took some adjusting to get it right, but it works a charmHS3 Pro Edition 3.0.0.435 (Windows 10 vmware)
BLOccupied:,UltraNetCam3:,weatherXML:,RFXCOM:,Current Cost 3P:,UltraGCIR3:
DMMQTT:,Kodi:,Z-Wave:,BLRadar:,EasyTrigger:,MySensors:,BLBackup:
Originally posted by dmurphy View PostI have a luimnance detector in room with shades....
I put my luminance detector outside the shades so that could not happen. That way it detects the outside luminance, not the luminance in the room. Make sure the outside luminance detector can register a high enough value. Everspring ST-815 can not...it maxes at 3000 lux which a cloudy day can exceed. I'm using Mi (aka Lumi, aka Aqara) Zigbee sensors which register up to 83,000 lux...HS4 Pro Edition 4.2.5.0 running on Lenovo ThinkCenter & Debian Linux
Plugins: Z-Wave (via Nortek USB stick
Home Assistant 2021.10.6 running on HA "Blue" ODROID-N2
Add-ons: Android Debug Bridge, Duck DNS, ESPHome, File Editor, Glances, HA Google Drive Backup, InfluxDB, Log Viewer, MariaDB, Mosquitto broker, NGINX SSL Proxy, Node-RED, Portainer, SSH & Web Terminal, Samba, TasmoAdmin, UniFi Controller, Visual Studio Code, WireGuard, Zigbee2mqtt, Z-Wave JS to MQTT
Integrations: AccuWeather, Alexa Media Player, Glances, Google Nest, HACS, HomeSeer, Insteon, IPP, Life360, Local IP, Logitech Harmony Hub, Mobile App, MQTT, My Garage, OpenWeather, Spotify, Tuya Local. Ubiquiti UniFi, Z-Wave JS
Insteon: 2413S Dual Band PLM
Zigbee: zzh! CC2652R Rev A
Z-Wave: RaZberry daughtercard on RPi 1B via ser2net
- Likes 1
Took some adjusting to get it right, but it works a charmHS 4.2.8.0: 2134 Devices 1252 Events
I just started seeing this today:
5/20/2021 10:52:02
HomeSeer
Error
Compiling script Astronomical.vb: compiler initialization failed unexpectedly: The system cannot find the file specified.
5/20/2021 10:52:02
HomeSeer
Error
Compiling script Astronomical.vb: could not find library 'Scheduler.dll'
I am running HS4 Pro, which I upgraded to last week. Scheduler.dll is present in the root directory. Any help to fix would be appreciated. Thanks."Living with technology means living in a [constant] state of flux." S. Higgenbotham, 2023
Originally posted by Richel View PostI just started seeing this today:
5/20/2021 10:52:02
HomeSeer
Error
5/20/2021 10:52:02
HomeSeer
Error
If that fails, check that it works when you start Homeseer from the Desktop Icon.
Originally posted by jon00 View Post
I expect you are using Task Scheduler to start Homeseer? In the Task/Actions/Edit Action, make sure you place the full path to Homeseer in the Start in field i.e. "C:\Program Files (x86)\HomeSeer HS4"
If that fails, check that it works when you start Homeseer from the Desktop Icon."Living with technology means living in a [constant] state of flux." S. Higgenbotham, 2023
I am just seeing this solution and it is exactly what I have been looking for. However, I am not very familiar with how to use scripts in events. Can someone help me with this and also, where exactly in the script to I have to enter my coordinates? Sorry for the dumb questions but I would like to use this idea but I have no knowledge of VB.
A similar project, with setup instructions: https://forums.homeseer.com/forum/de...d-moon-project
