Originally posted by pcgirl65
View Post
' Version: 30 September 2021 B 'From c code posted here: http://www.psa.es/sdg/sunpos.htm 'VB.NET Conversion posted here: http://www.vbforums.com/showthread.php?832645-Solar-position-calculator 'converted for HomeSeer use by Sparkman v1.0 'Modified to allow for determining Sunrise and Sunset Azimuths by aa6vh 'Requires two Virtual Devices to hold the info: Night and WxSolar Imports System.Math Private Function BearConvert(ByVal sBear As String) As String If IsNumeric(sBear) = False Then Return "-" Dim iBear As Integer = CInt(sBear) Do While iBear >= 360 iBear = iBear - 360 Loop Do While iBear < 0 iBear = iBear + 360 Loop iBear = CInt(Math.Round(CSng((iBear * 2) / 45))) Dim sDeg As String = "N,NNE,NE,ENE,E,ESE,SE,SSE,S,SSW,SW,WSW,W,WNW,NW,NNE,N" Dim buff(18) As String buff = sDeg.Split(",") Return buff(iBear) End Function Private Sub SolarPosition(ByRef dt As DateTime, ByRef sAzm As String, ByRef sAlt As String) Dim Debug As Boolean = False Dim logName As String = "Solar" Dim dLatitude As Double = 34.2220281 Dim dLongitude As Double = -119.1724294 Dim pi As Double = 3.14159265358979 Dim rad As Double = pi / 180 Dim dEarthMeanRadius As Double = 6371.01 Dim dAstronomicalUnit As Double = 149597890 Dim iYear As Integer = dt.Year Dim iMonth As Integer = dt.Month Dim iDay As Integer = dt.Day Dim dHours As Double = dt.Hour Dim dMinutes As Double = dt.Minute Dim dSeconds As Double = dt.Second Dim dZenithAngle As Double Dim dZenithAngleParallax As Double Dim dAzimuth As Double Dim dAltitudeAngle As Double Dim dElapsedJulianDays As Double Dim dDecimalHours As Double Dim dEclipticLongitude As Double Dim dEclipticObliquity As Double Dim dRightAscension As Double Dim dDeclination As Double Dim dY As Double Dim dX As Double Dim dJulianDate As Double Dim liAux1 As Integer Dim liAux2 As Integer Dim dMeanLongitude As Double Dim dMeanAnomaly As Double Dim dOmega As Double Dim dSin_EclipticLongitude As Double Dim dGreenwichMeanSiderealTime As Double Dim dLocalMeanSiderealTime As Double Dim dLatitudeInRadians As Double Dim dHourAngle As Double Dim dCos_Latitude As Double Dim dSin_Latitude As Double Dim dCos_HourAngle As Double Dim dParallax As Double Try If Debug Then hs.WriteLog(logName, CStr(iMonth) + "-" + CStr(iDay) + "-" + CStr(iYear) + " " + CStr(dHours) + ":" + CStr(dMinutes) + ":" + CStr(dSeconds)) ' Calculate difference in days between the current Julian Day and JD 2451545.0, which is noon 1 January 2000 Universal Time ' Calculate time of the day in UT decimal hours dDecimalHours = dHours + (dMinutes + dSeconds / 60.0) / 60.0 ' Calculate current Julian Day liAux1 = (iMonth - 14) \ 12 liAux2 = (1461 * (iYear + 4800 + liAux1)) \ 4 + (367 * (iMonth - 2 - 12 * liAux1)) \ 12 - (3 * ((iYear + 4900 + liAux1) \ 100)) \ 4 + iDay - 32075 dJulianDate = CDbl(liAux2) - 0.5 + dDecimalHours / 24.0 ' Calculate difference between current Julian Day and JD 2451545.0 dElapsedJulianDays = dJulianDate - 2451545.0 If Debug Then hs.writelog(logName,"Elapsed Julian Days Since 2000/01/01: " & CStr(dElapsedJulianDays)) ' Calculate ecliptic coordinates (ecliptic longitude and obliquity of the ecliptic in radians but without limiting the angle to be less than 2*Pi ' (i.e., the result may be greater than 2*Pi) dOmega = 2.1429 - 0.0010394594 * dElapsedJulianDays dMeanLongitude = 4.895063 + 0.017202791698 * dElapsedJulianDays ' Radians dMeanAnomaly = 6.24006 + 0.0172019699 * dElapsedJulianDays dEclipticLongitude = dMeanLongitude + 0.03341607 * Math.Sin(dMeanAnomaly) + 0.00034894 * Math.Sin(2 * dMeanAnomaly) - 0.0001134 - 0.0000203 * Math.Sin(dOmega) dEclipticObliquity = 0.4090928 - 0.000000006214 * dElapsedJulianDays + 0.0000396 * Math.Cos(dOmega) If Debug Then hs.writelog(logName,"Ecliptic Longitude: " & CStr(dEclipticLongitude)) If Debug Then hs.writelog(logName,"Ecliptic Obliquity: " & CStr(dEclipticObliquity)) ' Calculate celestial coordinates ( right ascension and declination ) in radians but without limiting the angle to be less than 2*Pi (i.e., the result may be greater than 2*Pi) dSin_EclipticLongitude = Math.Sin(dEclipticLongitude) dY = Math.Cos(dEclipticObliquity) * dSin_EclipticLongitude dX = Math.Cos(dEclipticLongitude) dRightAscension = Math.Atan2(dY, dX) If dRightAscension < 0.0 Then dRightAscension = dRightAscension + (2 * pi) End If dDeclination = Math.Asin(Math.Sin(dEclipticObliquity) * dSin_EclipticLongitude) If Debug Then hs.writelog(logName,"Declination: " & CStr(dDeclination)) ' Calculate local coordinates ( azimuth and zenith angle ) in degrees dGreenwichMeanSiderealTime = 6.6974243242 + 0.0657098283 * dElapsedJulianDays + dDecimalHours dLocalMeanSiderealTime = (dGreenwichMeanSiderealTime * 15 + dLongitude) * rad dHourAngle = dLocalMeanSiderealTime - dRightAscension If Debug Then hs.writelog(logName,"Hour Angle: " & CStr(dHourAngle)) dLatitudeInRadians = dLatitude * rad dCos_Latitude = Math.Cos(dLatitudeInRadians) dSin_Latitude = Math.Sin(dLatitudeInRadians) dCos_HourAngle = Math.Cos(dHourAngle) dZenithAngle = (Math.Acos(dCos_Latitude * dCos_HourAngle * Math.Cos(dDeclination) + Math.Sin(dDeclination) * dSin_Latitude)) dY = -Math.Sin(dHourAngle) dX = Math.Tan(dDeclination) * dCos_Latitude - dSin_Latitude * dCos_HourAngle dAzimuth = Math.Atan2(dY, dX) If dAzimuth < 0.0 Then dAzimuth = dAzimuth + (2 * pi) End If dAzimuth = dAzimuth / rad If Debug Then hs.writelog(logName,"Azimuth: " & CStr(dAzimuth)) ' Parallax Correction dParallax = (dEarthMeanRadius / dAstronomicalUnit) * Math.Sin(dZenithAngle) dZenithAngleParallax = (dZenithAngle + dParallax) / rad dAltitudeAngle = (dZenithAngleParallax * -1) + 90 If Debug Then hs.writelog(logName,"Altitude Angle: " & Math.Round(dAltitudeAngle).ToString) sAzm = Math.Round(dAzimuth).ToString sAlt = Math.Round(dAltitudeAngle).ToString Catch ex As Exception hs.WriteLog(logName, "Exception " & ex.ToString) End Try End Sub Public Sub SunRiseSet(parms As Object) ' Determines the azimuth of the sun for sunrise and sunset times Dim buff As String Dim sAzm As String = "", sAlt As String = "", sAzms As String = "", sAlts As String = "" buff = hs.Sunrise() Dim dt As DateTime = DateTime.Parse(buff) dt = dt.ToUniversalTime() SolarPosition(dt, sAzm, sAlt) buff = hs.Sunset() dt = DateTime.Parse(buff) dt = dt.ToUniversalTime() SolarPosition(dt, sAzms, sAlts) buff = LCase(hs.Sunrise() + " " + sAzm + "°/" + hs.Sunset() + " " + sAzms + "°") hs.SetDeviceStringByName("Night", buff, True) End Sub Sub Main(parms As Object) ' Determines the current azimuth and altitude angle of the sun Dim dt As DateTime = DateTime.UtcNow() Dim sAzm As String = "", sAlt As String = "", sBearing As String SolarPosition(dt, sAzm, sAlt) Dim buff As String = Format(Now(), "ddd h:mmtt") sBearing = BearConvert(sAzm) If CInt(sAlt) < 0 Then hs.SetDeviceStringByName("WxSolar", buff + " Nighttime", True) Else hs.SetDeviceStringByName("WxSolar", buff + " Azmth: " + _ sAzm + "° (" + sBearing + "), Alt: " + sAlt + "°", True) End If End Sub
To use, simply create an event action of "Run script", supplying the function name you want to run (Main or SunRiseSet)
