Hi There,
I have a Dreamscreen HD which can be controlled over IP.
I made a basic script to control some of its functions.
Im no professional coder so there probably some improvements possible
VB.Net
To use it see the attached picture.
Options for the start script:
For the off function to work you need to have the Dreamscreen device in a group! RGB function isn't implemented because of all the CRC calculations that are possible and i dont have the calculator function working. For that part i could use some help.
The Rev4 documentation is a bit harder to find but a you can download it from here
edit: The Off function doesn't always work at all. For now random working. When Sending of and no response. I open the app and send it again and then it works so not really stable...
VB.Net
Imports System.IO Imports System.Net.Sockets.Socket Imports System.Text Imports System.Net Imports System.Net.Sockets 'The static var below can be used with the CRC calculated function below 'Static uartComm_crc8_table = new byte[]{"&H2A","&H2D","&H70","&H77","&H7E","&H79","&H6C","&H6B","&H62","&H65","&H48","&H4F","&H46","&H41","&H54","&H53","&H5A","&H5D","&HE0","&HE7","&HEE","&HE9","&HFC","&HFB","&HF2","&HF5","&HD8","&HDF","&HD6","&HD1","&HC4","&HC3","&HCA","&HCD","&H90","&H97","&H9E","&H99","&H8C","&H8B","&H82","&H85","&HA8","&HAF","&HA6","&HA1","&HB4","&HB3","&HBA","&HBD","&HC7","&HC0","&HC9","&HCE","&HDB","&HDC","&HD5","&HD2","&HFF","&HF8","&HF1","&HF6","&HE3","&HE4","&HED","&HEA","&HB7","&HB0","&HB9","&HBE","&HAB","&HAC","&HA5","&HA2","&H8F","&H88","&H81","&H86","&H93","&H94","&H9D","&H9A","&H27","&H20","&H29","&H2E","&H3B","&H3C","&H35","&H32","&H1F","&H18","&H11","&H16","&H03","&H04","&H0D","&H0A","&H57","&H50","&H59","&H5E","&H4B","&H4C","&H45","&H42","&H6F","&H68","&H61","&H66","&H73","&H74","&H7D","&H7A","&H89","&H8E","&H87","&H80","&H95","&H92","&H9B","&H9C","&HB1","&HB6","&HBF","&HB8","&HAD","&HAA","&HA3","&HA4","&HF9","&HFE","&HF7","&HF0","&HE5","&HE2","&HEB","&HEC","&HC1","&HC6","&HCF","&HC8","&HDD","&HDA","&HD3","&HD4","&H69","&H6E","&H67","&H60","&H75","&H72","&H7B","&H7C","&H51","&H56","&H5F","&H58","&H4D","&H4A","&H43","&H44","&H19","&H1E","&H17","&H10","&H05","&H02","&H0B","&H0C","&H21","&H26","&H2F","&H28","&H3D","&H3A","&H33","&H34","&H4E","&H49","&H40","&H47","&H52","&H55","&H5C","&H5B","&H76","&H71","&H78","&H7F","&H6A","&H6D","&H64","&H63","&H3E","&H39","&H30","&H37","&H22","&H25","&H2C","&H2B","&H06","&H01","&H08","&H0F","&H1A","&H1D","&H14","&H13","&HAE","&HA9","&HA0","&HA7","&HB2","&HB5","&HBC","&HBB","&H9 ","&H91","&H98","&H9F","&H8A","&H8D","&H84","&H83","&HDE","&HD9","&HD0","&HD7","&HC2","&HC5","&HCC","&HCB","&HE6","&HE1","&HE8","&HEF","&HFA","&HFD","&HF4","&HF3"} Function Start (Byval modus As String ) Dim GLOIP As IPAddress = System.Net.IPAddress.Parse("192.168.1.19") 'use a static DHCP lease!! Dim GLOINTPORT As Integer Dim bytCommand As Byte() = New Byte(){}' empty array because it will be filled by function ModeToByte bytcommand = ModeToByte (modus) Dim udpClient As New UdpClient Dim pRet As Integer Try GLOINTPORT = 8888 udpClient.Connect(GLOIP, GLOINTPORT) pRet = udpClient.Send(bytCommand, bytCommand.Length) Catch ex As Exception hs.WriteLog("Dreamscreen error: ",ex.Message) End Try udpClient.Close() End Function Function ModeToByte (Byval mode as string) As Byte() Dim result As Byte() = New Byte() {} Dim AmbModes(5) As String 'mode,ambientscene,R,G,B If (mode.Length > 5) Then AmbModes = mode.Split(New Char() {":"c}) mode = AmbModes(0) End If Select Case mode Case "Ambient" hs.writelog("dreamscreen",AmbModes(1)) Select Case AmbModes(1) Case "Random" 'result = {"&HFC","06","00","&H21","03","&H0D","&H01,"&H5F"} 'is Random color no group specified (off will not work without group) result = {"&HFC","06","01","&H21","03","&H0D","&H01","&H3D"} 'is Random color group 1 Case "Fireside" 'result = {"&HFC","06","00","&H21","03","&H0D","&H02","&H56"} ' is Fireside no group specified (off will not work without group) result = {"&HFC","06","01","&H21","03","&H0D","&H02","&H34"} ' is Fireside group 1 Case "Twinkle" 'result = {"&HFC","06","00","&H21","03","&H0D","&H03","&H51"} ' is Twinkle no group specified (off will not work without group) result = {"&HFC","06","01","&H21","03","&H0D","&H03","&H33"} ' is Twinkle group 1 Case "Ocean" 'result = {"&HFC","06","00","&H21","03","&H0D","&H04","&H44"} ' is Ocean no group specified (off will not work without group) result = {"&HFC","06","01","&H21","03","&H0D","&H04","&H26"} ' is Ocean group 1 Case "July4th" 'result = {"&HFC","06","00","&H21","03","&H0D","&H05","&H43"} ' is July 4th no group specified (off will not work without group) result = {"&HFC","06","01","&H21","03","&H0D","&H05","&H21"} ' is July 4th group 1 Case "Holiday" 'result = {"&HFC","06","00","&H21","03","&H0D","&H06","&H4A"} ' is Holiday no group specified (off will not work without group) result = {"&HFC","06","01","&H21","03","&H0D","&H06","&H28"} ' is Holiday group 1 Case "Pop" '{"&HFC","06","00","&H21","03","&H0D","&H07","&H4D"} ' is Pop no group specified (off will not work without group) result = {"&HFC","06","01","&H21","03","&H0D","&H07","&H2F"} ' is Pop group 1 Case "EnchantedForest" result = {"&HFC","06","01","&H21","03","&H0D","&H08","&H02"} ' is enchanted forest group 1 Case "RGB" hs.writelog("Dreamscreen","RGB isn't supported yet") Case Else hs.WriteLog("Dreamscreen Ambient scene","Incorrect scene specifief: >>" & AmbModes(1) &"<< Choose from: Random, Fireside, Twinkle, Ocean, July4th, Holiday, Pop, EnchantedForest" ) end Select Case "Off" ' result = {"&HFC","&H06","&H00","&H21","&H03","&H01","&H00","&HA4"} 'no group specified result = {"&HFC","&H06","&H01","&H21","&H03","&H01","&H00","&HC6"} 'group 1 without group (parameter on 0) this doesn't work Case "Video" result = {"&HFC","06","00","&H21","03","01","01","&HA3"} 'no port switch is done Case "Music" result = {"&HFC","06","00","&H21","03","01","02","&HAA"} 'no port switch is done Case Else hs.WriteLog("Dreamscreen","incorrect mode selected: " & mode) End Select Return result End Function 'below is java code from rev4 documentation to calculated the CRC byte, For RGB functions this must be implemented 'Function uartComm_calculate_crc8(byte[] data) ' still java code ' byte size = (byte) (data[1] + 0x01); ' byte cntr = 0x00; ' byte crc = 0x00; ' while (cntr < size) { ' crc = uartComm_crc8_table[(byte) (crc ^ (data[cntr])) & 0xFF]; 'cntr++; '} 'return crc; '} 'End Function
Video Music Ambient:Random Fireside Ambient:Twinkle Ambient:Ocean Ambient:July4th Ambient:Holiday Ambient:Pop Ambient:EnchantedForest Ambient:RGB Off
