I wrote up a script for my monoprice amp. I have 5 of these split across 3 locations. So i needed to have 3 com posts listed over my 28 zones.
I have 3 functions on this script. First is adjusting the turning on and off each zone and adjusting volume in 1 portion. Second to adjust the The channels. Third to query the zones to update the devices. Unfortunately Each running of the script opens and closes the comp ports. So if you try to do too many functions at the same time it will not work. I don't know how to keep the comports open for the scripts to run over and over on short notice. The only parameter needed is to Address the virtual address as A1-18 for volume, C 1 - 18 for channel. Then also modify the Comports as needed.
Imports System.Threading Imports System.IO.Ports Public COMPort As New SerialPort() Public Sub Main(ByVal Parms as Object) Dim ParmArray() As String= Parms.tostring.split(",") Dim DevRef as String = CStr(ParmArray(0)) Dim Com as String Com = "" Dim DevVal as String DevVal = hs.DeviceExistsCode(DeVRef) Dim Zone as String Dim Command as string Dim Vol as Object Dim Comm as String Comm = "" Dim Power as String Dim rxBuff as String hs.writelog("Audio", "Starting script: Device is set to " & DevRef) If StrComp (DevRef, "A1", vbTextCompare) = 0 Then Zone = 11 Com = "Com4" Elseif StrComp (DevRef, "A2", vbTextCompare) = 0 Then Zone = 11 Com = "Com4" Elseif StrComp (DevRef, "A3", vbTextCompare) = 0 Then Zone = 13 Com = "Com4" Elseif StrComp (DevRef, "A4", vbTextCompare) = 0 Then Zone = 14 Com = "Com4" Elseif StrComp (DevRef, "A5", vbTextCompare) = 0 Then Zone = 15 Com = "Com4" Elseif StrComp (DevRef, "A6", vbTextCompare) = 0 Then Zone = 16 Com = "Com4" Elseif StrComp (DevRef, "A7", vbTextCompare) = 0 Then Zone = 21 Com = "Com4" Elseif StrComp (DevRef, "A8", vbTextCompare) = 0 Then Zone = 22 Com = "Com4" Elseif StrComp (DevRef, "A9", vbTextCompare) = 0 Then Zone = 23 Com = "Com4" Elseif StrComp (DevRef, "A10", vbTextCompare) = 0 Then Zone = 24 Com = "Com4" Elseif StrComp (DevRef, "A11", vbTextCompare) = 0 Then Zone = 25 Com = "Com4" Elseif StrComp (DevRef, "A12", vbTextCompare) = 0 Then Zone = 26 Com = "Com4" Elseif StrComp (DevRef, "A13", vbTextCompare) = 0 Then Zone = 31 Com = "Com4" Elseif StrComp (DevRef, "A14", vbTextCompare) = 0 Then Zone = 32 Com = "Com4" Elseif StrComp (DevRef, "A15", vbTextCompare) = 0 Then Zone = 33 Com = "Com4" Elseif StrComp (DevRef, "A16", vbTextCompare) = 0 Then Zone = 34 Com = "Com4" Elseif StrComp (DevRef, "A17", vbTextCompare) = 0 Then Zone = 35 Com = "Com4" Elseif StrComp (DevRef, "A18", vbTextCompare) = 0 Then Zone = 36 Com = "Com4" Elseif StrComp (DevRef, "A19", vbTextCompare) = 0 Then Zone = 11 Com = "Com3" Elseif StrComp (DevRef, "A20", vbTextCompare) = 0 Then Zone = 12 Com = "Com3" Elseif StrComp (DevRef, "A21", vbTextCompare) = 0 Then Zone = 13 Com = "Com3" Elseif StrComp (DevRef, "A22", vbTextCompare) = 0 Then Zone = 14 Com = "Com3" Elseif StrComp (DevRef, "A23", vbTextCompare) = 0 Then Zone = 15 Com = "Com3" Elseif StrComp (DevRef, "A24", vbTextCompare) = 0 Then Zone = 16 Com = "Com3" Elseif StrComp (DevRef, "A25", vbTextCompare) = 0 Then Zone = 11 Com = "Com1" Elseif StrComp (DevRef, "A26", vbTextCompare) = 0 Then Zone = 12 Com = "Com1" Elseif StrComp (DevRef, "A27", vbTextCompare) = 0 Then Zone = 13 Com = "Com1" Elseif StrComp (DevRef, "A28", vbTextCompare) = 0 Then Zone = 14 Com = "Com1" Elseif StrComp (DevRef, "C1", vbTextCompare) = 0 Then Zone = 11 Com = "Com4" Elseif StrComp (DevRef, "C2", vbTextCompare) = 0 Then Zone = 11 Com = "Com4" Elseif StrComp (DevRef, "C3", vbTextCompare) = 0 Then Zone = 13 Com = "Com4" Elseif StrComp (DevRef, "C4", vbTextCompare) = 0 Then Zone = 14 Com = "Com4" Elseif StrComp (DevRef, "C5", vbTextCompare) = 0 Then Zone = 15 Com = "Com4" Elseif StrComp (DevRef, "C6", vbTextCompare) = 0 Then Zone = 16 Com = "Com4" Elseif StrComp (DevRef, "C7", vbTextCompare) = 0 Then Zone = 21 Com = "Com4" Elseif StrComp (DevRef, "C8", vbTextCompare) = 0 Then Zone = 22 Com = "Com4" Elseif StrComp (DevRef, "C9", vbTextCompare) = 0 Then Zone = 23 Com = "Com4" Elseif StrComp (DevRef, "C10", vbTextCompare) = 0 Then Zone = 24 Com = "Com4" Elseif StrComp (DevRef, "C11", vbTextCompare) = 0 Then Zone = 25 Com = "Com4" Elseif StrComp (DevRef, "C12", vbTextCompare) = 0 Then Zone = 26 Com = "Com4" Elseif StrComp (DevRef, "C13", vbTextCompare) = 0 Then Zone = 31 Com = "Com4" Elseif StrComp (DevRef, "C14", vbTextCompare) = 0 Then Zone = 32 Com = "Com4" Elseif StrComp (DevRef, "C15", vbTextCompare) = 0 Then Zone = 33 Com = "Com4" Elseif StrComp (DevRef, "C16", vbTextCompare) = 0 Then Zone = 34 Com = "Com4" Elseif StrComp (DevRef, "C17", vbTextCompare) = 0 Then Zone = 35 Com = "Com4" Elseif StrComp (DevRef, "C18", vbTextCompare) = 0 Then Zone = 36 Com = "Com4" Elseif StrComp (DevRef, "C19", vbTextCompare) = 0 Then Zone = 11 Com = "Com3" Elseif StrComp (DevRef, "C20", vbTextCompare) = 0 Then Zone = 12 Com = "Com3" Elseif StrComp (DevRef, "C21", vbTextCompare) = 0 Then Zone = 13 Com = "Com3" Elseif StrComp (DevRef, "C22", vbTextCompare) = 0 Then Zone = 14 Com = "Com3" Elseif StrComp (DevRef, "C23", vbTextCompare) = 0 Then Zone = 15 Com = "Com3" Elseif StrComp (DevRef, "C24", vbTextCompare) = 0 Then Zone = 16 Com = "Com3" Elseif StrComp (DevRef, "C25", vbTextCompare) = 0 Then Zone = 11 Com = "Com1" Elseif StrComp (DevRef, "C26", vbTextCompare) = 0 Then Zone = 12 Com = "Com1" Elseif StrComp (DevRef, "C27", vbTextCompare) = 0 Then Zone = 13 Com = "Com1" Elseif StrComp (DevRef, "C28", vbTextCompare) = 0 Then Zone = 14 Com = "Com1" End If hs.writelog("Audio", "Zone is " & Zone & " Com is " & Com) Dim Type as String Type = DevRef.Substring(0, 1) hs.writelog("Audio", "Type is " & Type) If StrComp (Type, "A", vbTextCompare) = 0 Then Vol = hs.DeviceValue(DevVal) If Vol <10 and Vol >0 then Vol = "0" & Vol End if If Vol <37 and Vol >0 then command = "<" & Zone & "VO" & Vol Elseif vol < 1 Vol = "0" & Vol command = "<" & Zone & "PR00" End if hs.writelog("Audio", "Volume is " & Vol) COMPort.PortName = Com COMPort.BaudRate = 9600 COMPort.Parity = System.IO.Ports.Parity.None COMPort.DataBits = 8 COMPort.StopBits = System.IO.Ports.StopBits.One Comport.ReadTimeout = 1000 hs.writelog("Audio", "Main() Called - Attempting To Open") If COMPort.IsOpen = False Then COMPort.Open() End If Comm = "?" & Zone & "PR" & vbCr hs.writelog("Audio", "Sending: " & Comm) 'writes to com port COMPort.Write(Comm) System.Threading.Thread.Sleep(600) 'Reading the com port: rxBuff = (COMPort.ReadExisting) hs.writelog("Audio", "Port Open - Sending Data") Comm = "<" & Zone & "PR01" & vbCr hs.writelog("Audio", "Sending: " & Comm) 'writes to com port COMPort.Write(Comm) System.Threading.Thread.Sleep(600) 'Reading the com port: rxBuff = (COMPort.ReadExisting) If rxBuff <> "" Then hs.writelog("Audio", "Received:" & rxBuff) rxBuff = "" End If hs.writelog("Audio", "Port Open - Sending Data") Comm = Command & vbCr hs.writelog("Audio", "Sending: " & Comm) 'writes to com port COMPort.Write(Comm) System.Threading.Thread.Sleep(600) 'Reading the com port: rxBuff = (COMPort.ReadExisting) If rxBuff <> "" Then hs.writelog("Audio", "Received:" & rxBuff) rxBuff = "" End If COMPort.close() hs.writelog("Audio", "Ended") Exit Sub Elseif StrComp (Type, "C", vbTextCompare) = 0 Then Vol = hs.DeviceValue(DevVal) If Vol <10 and Vol >0 then Vol = "0" & Vol End if If Vol <6 and Vol >0 then command = "<" & Zone & "CH" & Vol Elseif vol < 1 Vol = "0" & Vol command = "<" & Zone & "PR00" End if hs.writelog("Audio", "Volume is " & Vol) COMPort.PortName = Com COMPort.BaudRate = 9600 COMPort.Parity = System.IO.Ports.Parity.None COMPort.DataBits = 8 COMPort.StopBits = System.IO.Ports.StopBits.One Comport.ReadTimeout = 1000 hs.writelog("Audio", "Main() Called - Attempting To Open") If COMPort.IsOpen = False Then COMPort.Open() End If Comm = "?" & Zone & "PR" & vbCr hs.writelog("Audio", "Sending: " & Comm) 'writes to com port COMPort.Write(Comm) System.Threading.Thread.Sleep(600) 'Reading the com port: rxBuff = (COMPort.ReadExisting) hs.writelog("Audio", "Port Open - Sending Data") Comm = "<" & Zone & "PR01" & vbCr hs.writelog("Audio", "Sending: " & Comm) 'writes to com port COMPort.Write(Comm) System.Threading.Thread.Sleep(600) 'Reading the com port: rxBuff = (COMPort.ReadExisting) If rxBuff <> "" Then hs.writelog("Audio", "Received:" & rxBuff) rxBuff = "" End If hs.writelog("Audio", "Port Open - Sending Data") Comm = Command & vbCr hs.writelog("Audio", "Sending: " & Comm) 'writes to com port COMPort.Write(Comm) System.Threading.Thread.Sleep(600) 'Reading the com port: rxBuff = (COMPort.ReadExisting) If rxBuff <> "" Then hs.writelog("Audio", "Received:" & rxBuff) rxBuff = "" End If COMPort.close() hs.writelog("Audio", "Ended") Exit Sub Elseif StrComp (Type, "B", vbTextCompare) = 0 Then hs.writelog("Audio", "Starting script: Updating all Devices") COMPort.PortName = "COM4" COMPort.BaudRate = 9600 COMPort.Parity = System.IO.Ports.Parity.None COMPort.DataBits = 8 COMPort.StopBits = System.IO.Ports.StopBits.One Comport.ReadTimeout = 1000 hs.writelog("Audio", "Main() Called - Attempting To Open") If COMPort.IsOpen = False Then COMPort.Open() End If hs.writelog("Audio", "Port Open - Sending Data") Com = "?10" & vbCr hs.writelog("Audio", "Sending: " & Com) 'writes to com port COMPort.Write(Com) System.Threading.Thread.Sleep(600) 'Reading the com port: rxBuff = (COMPort.ReadExisting) Dim Volume as String Dim Channel as String Zone = rxBuff.Substring(7, 2) Power = rxBuff.Substring(11, 2) Volume = rxBuff.Substring(17, 2) Channel = rxBuff.Substring(25, 2) hs.writelog("Audio", "Received:" & rxBuff) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A1") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C1") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A1") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Zone = rxBuff.Substring(34, 2) Power = rxBuff.Substring(38, 2) Volume = rxBuff.Substring(44, 2) Channel = rxBuff.Substring(52, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A2") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C2") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A2") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Zone = rxBuff.Substring(61, 2) Power = rxBuff.Substring(65, 2) Volume = rxBuff.Substring(71, 2) Channel = rxBuff.Substring(79, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A3") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C3") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A3") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Zone = rxBuff.Substring(88, 2) Power = rxBuff.Substring(92, 2) Volume = rxBuff.Substring(98, 2) Channel = rxBuff.Substring(106, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A4") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C4") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A4") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Zone = rxBuff.Substring(115, 2) Power = rxBuff.Substring(119, 2) Volume = rxBuff.Substring(125, 2) Channel = rxBuff.Substring(133, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A5") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C5") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A5") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Zone = rxBuff.Substring(142, 2) Power = rxBuff.Substring(146, 2) Volume = rxBuff.Substring(152, 2) Channel = rxBuff.Substring(160, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A6") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C6") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A6") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Com = "?20" & vbCr hs.writelog("Audio", "Sending: " & Com) 'writes to com port COMPort.Write(Com) System.Threading.Thread.Sleep(600) 'Reading the com port: rxBuff = (COMPort.ReadExisting) Zone = rxBuff.Substring(7, 2) Power = rxBuff.Substring(11, 2) Volume = rxBuff.Substring(17, 2) Channel = rxBuff.Substring(25, 2) hs.writelog("Audio", "Received:" & rxBuff) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A7") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C7") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A7") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Zone = rxBuff.Substring(34, 2) Power = rxBuff.Substring(38, 2) Volume = rxBuff.Substring(44, 2) Channel = rxBuff.Substring(52, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A8") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C8") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A8") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Zone = rxBuff.Substring(61, 2) Power = rxBuff.Substring(65, 2) Volume = rxBuff.Substring(71, 2) Channel = rxBuff.Substring(79, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A9") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C9") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A9") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Zone = rxBuff.Substring(88, 2) Power = rxBuff.Substring(92, 2) Volume = rxBuff.Substring(98, 2) Channel = rxBuff.Substring(106, 2) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A10") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C10") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A10") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) Zone = rxBuff.Substring(115, 2) Power = rxBuff.Substring(119, 2) Volume = rxBuff.Substring(125, 2) Channel = rxBuff.Substring(133, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A11") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C11") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A11") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Zone = rxBuff.Substring(142, 2) Power = rxBuff.Substring(146, 2) Volume = rxBuff.Substring(152, 2) Channel = rxBuff.Substring(160, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A12") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C12") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A12") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Com = "?30" & vbCr hs.writelog("Audio", "Sending: " & Com) 'writes to com port COMPort.Write(Com) System.Threading.Thread.Sleep(600) 'Reading the com port: rxBuff = (COMPort.ReadExisting) Zone = rxBuff.Substring(7, 2) Power = rxBuff.Substring(11, 2) Volume = rxBuff.Substring(17, 2) Channel = rxBuff.Substring(25, 2) hs.writelog("Audio", "Received:" & rxBuff) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A13") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C13") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A13") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Zone = rxBuff.Substring(34, 2) Power = rxBuff.Substring(38, 2) Volume = rxBuff.Substring(44, 2) Channel = rxBuff.Substring(52, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A14") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C14") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A14") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Zone = rxBuff.Substring(61, 2) Power = rxBuff.Substring(65, 2) Volume = rxBuff.Substring(71, 2) Channel = rxBuff.Substring(79, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A15") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C15") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A15") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Zone = rxBuff.Substring(88, 2) Power = rxBuff.Substring(92, 2) Volume = rxBuff.Substring(98, 2) Channel = rxBuff.Substring(106, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A16") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C16") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A16") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Zone = rxBuff.Substring(115, 2) Power = rxBuff.Substring(119, 2) Volume = rxBuff.Substring(125, 2) Channel = rxBuff.Substring(133, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A17") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C17") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A17") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Zone = rxBuff.Substring(142, 2) Power = rxBuff.Substring(146, 2) Volume = rxBuff.Substring(152, 2) Channel = rxBuff.Substring(160, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A18") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C18") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A18") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If COMPort.close() System.Threading.Thread.Sleep(600) hs.writelog("Audio", "Starting script: Updating all Devices") COMPort.PortName = "COM3" COMPort.BaudRate = 9600 COMPort.Parity = System.IO.Ports.Parity.None COMPort.DataBits = 8 COMPort.StopBits = System.IO.Ports.StopBits.One Comport.ReadTimeout = 1000 hs.writelog("Audio", "Main() Called - Attempting To Open") If COMPort.IsOpen = False Then COMPort.Open() End If hs.writelog("Audio", "Port Open - Sending Data") Com = "?10" & vbCr hs.writelog("Audio", "Sending: " & Com) 'writes to com port COMPort.Write(Com) System.Threading.Thread.Sleep(600) 'Reading the com port: rxBuff = (COMPort.ReadExisting) Zone = rxBuff.Substring(7, 2) Power = rxBuff.Substring(11, 2) Volume = rxBuff.Substring(17, 2) Channel = rxBuff.Substring(25, 2) hs.writelog("Audio", "Received:" & rxBuff) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A19") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C19") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A19") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Zone = rxBuff.Substring(34, 2) Power = rxBuff.Substring(38, 2) Volume = rxBuff.Substring(44, 2) Channel = rxBuff.Substring(52, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A20") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C20") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A20") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Zone = rxBuff.Substring(61, 2) Power = rxBuff.Substring(65, 2) Volume = rxBuff.Substring(71, 2) Channel = rxBuff.Substring(79, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A21") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C21") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A21") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Zone = rxBuff.Substring(88, 2) Power = rxBuff.Substring(92, 2) Volume = rxBuff.Substring(98, 2) Channel = rxBuff.Substring(106, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A22") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C22") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A22") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Zone = rxBuff.Substring(115, 2) Power = rxBuff.Substring(119, 2) Volume = rxBuff.Substring(125, 2) Channel = rxBuff.Substring(133, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A23") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C23") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A23") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Zone = rxBuff.Substring(142, 2) Power = rxBuff.Substring(146, 2) Volume = rxBuff.Substring(152, 2) Channel = rxBuff.Substring(160, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A24") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C24") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A24") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If COMPort.close() System.Threading.Thread.Sleep(600) hs.writelog("Audio", "Starting script: Updating all Devices") COMPort.PortName = "COM1" COMPort.BaudRate = 9600 COMPort.Parity = System.IO.Ports.Parity.None COMPort.DataBits = 8 COMPort.StopBits = System.IO.Ports.StopBits.One Comport.ReadTimeout = 1000 hs.writelog("Audio", "Main() Called - Attempting To Open") If COMPort.IsOpen = False Then COMPort.Open() End If hs.writelog("Audio", "Port Open - Sending Data") Com = "?10" & vbCr hs.writelog("Audio", "Sending: " & Com) 'writes to com port COMPort.Write(Com) System.Threading.Thread.Sleep(600) 'Reading the com port: rxBuff = (COMPort.ReadExisting) If rxBuff = "" Then COMPort.close() hs.writelog("Audio", "Gazebo Stero is Off") Elseif rxBuff <>"" then Zone = rxBuff.Substring(7, 2) Power = rxBuff.Substring(11, 2) Volume = rxBuff.Substring(17, 2) Channel = rxBuff.Substring(25, 2) hs.writelog("Audio", "Received:" & rxBuff) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A25") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C25") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A25") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Zone = rxBuff.Substring(34, 2) Power = rxBuff.Substring(38, 2) Volume = rxBuff.Substring(44, 2) Channel = rxBuff.Substring(52, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A26") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C26") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A26") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Zone = rxBuff.Substring(61, 2) Power = rxBuff.Substring(65, 2) Volume = rxBuff.Substring(71, 2) Channel = rxBuff.Substring(79, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A27") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C27") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A27") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Zone = rxBuff.Substring(88, 2) Power = rxBuff.Substring(92, 2) Volume = rxBuff.Substring(98, 2) Channel = rxBuff.Substring(106, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) If Channel = 01 Then Channel = "Sonos" Elseif Channel = 02 Then Channel = "Computer" Elseif Channel = 03 Then Channel = "Tv" Elseif Channel = 04 Then Channel = "Alexa" Elseif Channel = 05 Then Channel = "Bluetooth" Elseif Channel = 06 Then Channel = "Chromecast" End If If Power = 01 Then DevVal = hs.DeviceExistsCode("A28") Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cc.ControlValue = Volume Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) DevVal = hs.DeviceExistsCode("C28") hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevVal,true ,Channel,false,true)) Elseif Power = 00 Then DevVal = hs.DeviceExistsCode("A28") Dim cd As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(DevVal, True, "(Value)", False, False) cd.ControlValue = Power Dim cs As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cd) End If Zone = rxBuff.Substring(115, 2) Power = rxBuff.Substring(119, 2) Volume = rxBuff.Substring(125, 2) Channel = rxBuff.Substring(133, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) Zone = rxBuff.Substring(142, 2) Power = rxBuff.Substring(146, 2) Volume = rxBuff.Substring(152, 2) Channel = rxBuff.Substring(160, 2) hs.writelog("Audio", "Zone:" & Zone & " has power at " & Power & " Volume at " & Volume & " Channel at " & Channel) End If COMPort.close() Exit Sub End IF End Sub
