I have just had a pergola installed on my terrace. It has three Somfy IO devices installed and naturally I'd like to integrate these into my HS3Pro setup. Am I right in thinking that I will also need to purchase some sort of Somfy interface in order to accomplish this? I've seen a MyLink - but I think this is only compatible with older Somfy RTS devices. Thanks in advance for any help you guys can provide.
Help with Somfy IO
Guest
I have the same problem. I found Izymo transmitter.
Maybe you could connect it to HS controlled relays. There would be no status info, but always something.
I second 's approach and just implemented it.
Outside, I have three awnings with Somfy IO. Although I could have gone for group control, I wanted to be able to control each awning individually. Working from this blog I found on controlling the Somfy Izymo 1822609 with a relay, I wondered whether I could use the NodeMCU ESP8266 (I've been buying them in bulk as they are a great way to control LED strips with WLED) instead. Of course you can! Tasmota provides a perfect solution to drive the relays.
Setting up Tasmota is super easy: flash the binary, bring it in your wifi network and configure the template to drive the relay(s). I went for an 8-channel relay but only use 6 relays: two for each IO control, one for up, one for down. Then enable MQTT so that you can use the excellent mcsMQTT plugin to be able to control each relay individually. See the Pi blog on how to wire things up.
My solution in HS3 is fairly basic and can no doubt be improved upon by folding the MQTT messaging into the device itself . I use a virtual device for each awning with an up, down and stop state. Events trigger from a change in state to send the appropriate messages over MQTT (up triggers relay 1 off and 2 on; down the other way around; stop switches both to off). Each awning has three events to correspond with the three states; all awnings are controlled in a single group by calling the relevant up/down/stop event for each individual awning.
The io-homecontrol protocol is used by both Somfy and Velux, so I believe you can use a Velux KLF 200 interface. I wrote some scripts to control my Velux roof awnings and blinds:
https://forums.homeseer.com/forum/de...klf200-control
I will probably get Somfy shutter motors in the future and am hoping to use this mechanism.
Originally posted by b_weijenberg View PostAs far as I know, Bond bridge does not support Somfy IO_Homecontrol.
It supports Somfy RTS but in that case better to use RFXCOM RFXtrx433XL as this device supports a lot more devices and cheaper compared to Bond Bridge Pro
And Bond Bridge supports huge list of devices, because it can learn both IR and RF signals of different frequencies (not fixed to 433 MGz)
Hi all - cross posting here from the Bond plugin board. I don't know anything about RTS or RFXCOM - trying to figure out which/what to learn to get my pergola and patio shades automated and stumbled on this thread. Here's my question in case anyone can help...
I've got three outdoor shades on my patio with Somfy motors, and a Struxure Pergola with a motor for the Louvers.- The shades are controlled by a Somfy 74300 - France remote, which has a sticker on the back that says TELIS-4SOLIRIS-PATIO US GX420
- The pergola is controlled by a Somfy 74300-France remote, which has a sticker on the back that says TELIS 4 RTS US PATIO GX431
How can I tell if they will work with a Bond Bridge? (and/or what other suggestions would folks have? I saw RTS RFX plugins but nothing seemed particularly straightforward. I do have a MyLink for the Pergola, but not for the shades...and I'm not sure how/if I can program the pergola as a fourth zone on the shades remote).
My goal is to be able to automate opening and closing of these via Homeseer. In an ideal world I would be able to know the state of each shade and the pergola louvers (open or closed, or ideally how much open or closed they are) but that is not P0.
Thanks in advance.
Originally posted by larrywal32 View PostHi all - cross posting here from the Bond plugin board.
Are you still on HS3?
@larrywal32:
Somfy IO is using bi-directional communication but is only supported by Somfy controllers.
Somfy RTS is a one-way communication without position indication. It is very easy to control Somfy RTS with the RFXCOM plug-in and RFXtrxUSB-RFX433.
You have a possibility to assign one preset in the Somfy RTS motor.
Steps to be taken in the RFXCOM plug-in:
1 Add a Somfy RTS Output device.
2 Put the Somfy motor in pairing mode to add a new remote (this RFXCOM output device)
3 Click the Program button on the RFXCOM device
Now you are able to control the Somfy RTS motor.
Bond bridge supports Somfy RTS https://forum.bondhome.io/search?q=somfy
Note: no need for Bond Pro, original Bond bridge is sufficient.
