Trying to copy files to Synology NAS using System.IO.File.Copy
    I can copy files on the local drives but not mapped drives?
    "c:\audio_artwork\ - works
    "W:\audio_artwork\ - does not work
    Started googling and didn't get far. Any help appreciated. Thanks.
    I remember reading somewhere that for some reason it's different when copying to mapped drives.
    Try: "W:\\audio_artwork\
    Notice the extra slash.
    If not, just try a search for writing to or copying to a NAS.
      Its a little bit more complicated than that. I do not believe "W:\\" will work.
      Mapped drives are done by user. If your homeseer is running under a different user, it might not see the mapped drive.
      You could try using the drive identifier name (where the double reverse slash is used): \\drive-name\directory
        I stand corrected. I was going by memory. I think that is the way I saw it before
          Thanks, I did get it working using \\NASname\folder\
