Post any questions, comments, or suggestions about the page in this thread. The File can be downloaded HERE
Streaming Audio/Video Webpage Discussion
Kyham
Take a look at the Hauppage plugin
The plugin can take captures in single view, AVI format, and streaming.
I currently have the single and AVI function running on my site. I did have streaming until I installed SP2 which killed it. Just haven't had the time to go back and try to get it going again. It was simple to run as supplied, but as all of us here, out of the box is usually not EXACTLY what we each want. I have changed the ASP's to run under the Touchpad interface. It takes a little more effort though. If you are happy with the standard HS web pages, you should have no problem.
And support is EXCELLENT!!!!!
insert Web Wrapper ?
What do I need to do so I can get HS menu to show on the top of your index.html page?HS2 Environment
Zotac 1.83 GHz Quadcore
HomeSeer Way2Call
Netiom-Xap board
opnode 1-wire 1.2.7
Plug-In's
WeatherXML 1.0.0.32
Pwr Link USB 1.0.0.13
mcsTemp V6.2.0.14
mcsXap V3.0.0.0/3.0.0.20
IM Connector 4.87.2.5
Sip Connector 2.56.2.4
RFXCOM 15.0.0.22
Odroid X2
Asterisk 11.5.1
FreePBX 2.11.0.42
WebMin 1.720
Xap Switchboard by Mi4
There is no place Like 127.0.0.1
Well inserting the web wrapper entries into the index.htm like I have done on other pages caused it to stop loading the channels when clicked on. Reinstalling from the zip file over top of the edited files fixed the problem.
Funny, I opened the index.htm file with Frontpage, renamed it to original_index.htm to back it up. I then edit the index.htm file to add webwrapper and then it wont try to connect to the stream. I then removed index.htm, renamed original_index.htm to index.htm and still no connect. Reinstalling from the zip file over top of the edited files fixed the problem. Just editting it seemed to cause the problem. Further investigation is required.
Later, Terry
Ok well I will keep hacking on it. if I get it working I will post back. Thanks for the reply.HS2 Environment
HomeSeer Way2Call
Netiom-Xap board
opnode 1-wire 1.2.7
Plug-In's
WeatherXML 1.0.0.32
mcsTemp V6.2.0.14
RFXCOM 15.0.0.22
Odroid X2
Asterisk 11.5.1
FreePBX 2.11.0.42
WebMin 1.720
Interesting. My security cameras are hooked up to modulators that transmit above the analog cable channels in the house CATV network. Can this plug in be used to command a CATV tuner card to tune to a specific cable channel, encode the video and transmit it over a broadband link to a remote browser?
Mike
Web Wrapper
I was able to utilize Web Wrapper by opening Index.html in Frontpage. Editing and saving html as an asp. Works great. Excellent John!!- Pete
Auto matorHomeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb- Mono 6.12.X - HSTouch on Intel tabletop tablets
HS4 Pro - V4.1.11.0 - Ubuntu 20.01/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.10.0.104
HS4 Lite -X10, UPB, Zigbee, ZWave and Wifi MQTT automation-Tasmota-Espurna. OmniPro 2, Russound zoned audio, Smartthings hub, Hubitat Hub, and Home Assistant
HomersBrain
Great contribution there John. It works fine in IE but not Firefox (my preferred browser). Whichever button I click, I get the NASA channel. Is anyone else having the same problem?
Just downloaded it, works great.
One question, you sayIt comes configured with a selection of TV and Radio broadcast sites, that your can customize to your liking. I you use Windows Media Encoder, to stream your web/security cams, they can be easily added to the page as well.sigpic
