If this is your first visit, be sure to check out the FAQ. You must register before you can post. Your first post will be checked for appropriate content
(SPAM) - please allow a bit of time for that. After that, you'll be able to post at will!
Great contribution there John. It works fine in IE but not Firefox (my preferred browser). Whichever button I click, I get the NASA channel. Is anyone else having the same problem?
Try using the IETab extension.. FF for some reason dont like the buttons on any of the custom built pages, things it to do with the Form Post method.
It comes configured with a selection of TV and Radio broadcast sites, that your can customize to your liking. I you use Windows Media Encoder, to stream your web/security cams, they can be easily added to the page as well.
How do you tell it to look at Windows Encoder for the video source?
Guest replied
Interesting. My security cameras are hooked up to modulators that transmit above the analog cable channels in the house CATV network. Can this plug in be used to command a CATV tuner card to tune to a specific cable channel, encode the video and transmit it over a broadband link to a remote browser?
Well inserting the web wrapper entries into the index.htm like I have done on other pages caused it to stop loading the channels when clicked on. Reinstalling from the zip file over top of the edited files fixed the problem.
Funny, I opened the index.htm file with Frontpage, renamed it to original_index.htm to back it up. I then edit the index.htm file to add webwrapper and then it wont try to connect to the stream. I then removed index.htm, renamed original_index.htm to index.htm and still no connect. Reinstalling from the zip file over top of the edited files fixed the problem. Just editting it seemed to cause the problem. Further investigation is required.
Karls,
If you want an excellent streaming package look for Webcam32 on EBay. I've seen it for as little as $10. I use it along with iVista and they both work equally as well.
Guest replied
Take a look at the Hauppage plugin
The plugin can take captures in single view, AVI format, and streaming.
I currently have the single and AVI function running on my site. I did have streaming until I installed SP2 which killed it. Just haven't had the time to go back and try to get it going again. It was simple to run as supplied, but as all of us here, out of the box is usually not EXACTLY what we each want. I have changed the ASP's to run under the Touchpad interface. It takes a little more effort though. If you are happy with the standard HS web pages, you should have no problem.
