sunrise/sunset script
  • Fuego
    He did ask for it as part of larger (alarm) script, though
    Anyway, here is my VB.NET flavour tuppence-worth:
    Private Function IsSun(Optional ByVal TimeToCheck As Date = Nothing) As Boolean
        If TimeToCheck = Nothing Then
            TimeToCheck = Now
        End If
        Return TimeToCheck >= hs.SunriseDt And TimeToCheck < hs.SunsetDt
    End Function
  • Rupp
    A script is not required to do this. You could set up and event that triggers on Daytime or Nighttime.
  • DanWheeler
    thank you for that script! it's the only one anywhere in the forum that actually works. There are all kinds of peculiarities with sunset/sunrise that cause problems but this script really works.
  • glabbeek
    That works!
    thanks a lot.
  • Guest's Avatar
    Guest replied
    Try this out, I threw it together in about 15 min. so did not have much time to debug it.
    sub main()
    dim currenttime
    dim sunset
    dim sunrise
    dim sunrisediff
    dim sensetdiff
    sunset = hs.sunset
    sunrise = hs.sunrise
    currenttime = formatdatetime (time, vbshorttime)
    sunrisediff = datediff("n", currenttime, sunrise)
    sunsetdiff = datediff("n", currenttime, sunset)
    if (sunrisediff <= 0) and (sunsetdiff >= 0) then
    hs.speak "It is light outside"
    else
    hs.speak "It is dark outside."
    end if
    end sub
  • glabbeek
    started a topic sunrise/sunset script
    As part of the script that I am writting to use with my alarm system, I want to compare whether the current time is before or after sunrise/sunset.
    Here is what I came up with, but it does not work correct.
    sub main()
    dim currenttime
    dim sunset
    dim sunrise
    sunset = hs.sunset
    msgbox currenttime & " sr: " & sunrise & " ss: " & sunset
    if (curerenttime <= sunrise) or (currenttime >= sunset) then
    hs.speak "It is dark outside"
    else
    hs.speak "It is light outside."
    end if
    end sub
    Can anybody help me out on this.
    Regards Willem-bram
