25 Aug 03
Changes have been made to the script:
Added flag aSetFlags. Default is set to False
This will prevent any flag settings when a new number is entered. Apparently this causes some names to not show up in the HSP panel. Recommended procedure for fixing problems you may have is to edit the addressbook.xml and change all references to cidflags=".." to cidflags="0". Any text editor will work, and you can use a search and replace to make it quick.
10 May 03
Moved some code into subs. In particular, first and last names, call counter, and date of last call.
Changed name of Sub "UpdateCustom2Field" to "BatchProcess"
Fixed a potential error in the sub that might cause improper indexing of call count and date.
Added capability to refresh all names in the ini to be the same as in the phonebook. Good for when the user changes names. To use this feature, run the Event (InitPhoneUtil) you created to create an index in the phonebook. If you have not created the event, then you will not have a cross index. If you have the event be sure that the script call is like this:
hs_Phone_Util.txt ("main","All")
----------------- End of Update Note----------------
This is the discussion thread for the new phonebook script. The script is an updated version of my previous script (My_Phone_Util.txt)
There are 3 files in the package.
1. The script: hs_Phone_Util.txt
2. The ini file: hs_Phone_Util.ini
3. And a readme file: hs_Phone_UtilReadme.txt
Extract the script to the scripts directory.
Place the ini file in your HomeSeer config directory.
Place the readme into a directory like \Doc for safekeeping.
Read the readme file first for an understanding of the application, what it does, and to decide if you want to use it. If you decide to use this script and have been using My_Phone_Util.txt, you need to replace the script name in the associated event. You will also need to create a new event to update your phonebook to include an index. This is explained in the readme file.
NOTE:
This is the first release. It may have a few bugs. If you discover a problem, please post it here and I will address it as quickly as possible.
regards,
GenevaDude
[This message was edited by GenevaDude on Sat, 10 May 2003 at 07:39 AM.]
[This message was edited by GenevaDude on Mon, 25 August 2003 at 07:46 AM.]
10 May 03
NOTE:
regards,
GenevaDude
