How to change Greeting Message remotely
    Is there a way to change the out going message (Greeting)on a mailbox by calling in and entering a DTMF button. I would like to change the out going message with out having to record it in front of the HS computer.
    Thanks All
    HS2 Environment
    Zotac 1.83 GHz Quadcore
    HomeSeer Way2Call
    Netiom-Xap board
    opnode 1-wire 1.2.7
    Plug-In's
    WeatherXML 1.0.0.32
    Pwr Link USB 1.0.0.13
    mcsTemp V6.2.0.14
    mcsXap V3.0.0.0/3.0.0.20
    IM Connector 4.87.2.5
    Sip Connector 2.56.2.4
    RFXCOM 15.0.0.22
    Odroid X2
    Asterisk 11.5.1
    FreePBX 2.11.0.42
    WebMin 1.720
    Xap Switchboard by Mi4
    There is no place Like 127.0.0.1
    I guess this is not possible to do?
    HS2 Environment
    HomeSeer Way2Call
    Netiom-Xap board
    opnode 1-wire 1.2.7
    Plug-In's
    WeatherXML 1.0.0.32
    mcsTemp V6.2.0.14
    RFXCOM 15.0.0.22
    Odroid X2
    Asterisk 11.5.1
    FreePBX 2.11.0.42
    WebMin 1.720
      I think you can only change the default greeting by using an event and keying in the text you want to change it too.
      -Rupp
        I never thought of that but I dont see my wife going to that much trouble. She wants to record it in her own voice from a phone . Oh well we will put it on the wish list. Thanks Rupp
        HS2 Environment
        HomeSeer Way2Call
        Netiom-Xap board
        opnode 1-wire 1.2.7
        Plug-In's
        WeatherXML 1.0.0.32
        mcsTemp V6.2.0.14
        RFXCOM 15.0.0.22
        Odroid X2
        Asterisk 11.5.1
        FreePBX 2.11.0.42
        WebMin 1.720
          You can make your own IVR script to do this. There are a few ways you could go about doing this.
          In Homeseer phone you can set a wav file to be the outgoing message. Using an IVR script your can use the RECORD: command to record a message and have it replace the outgoing WAV file that gets placed.
          EX.
          RECORD:c:\program files\homeseer\outgoing.wav
            Ok this is more of what I am looking for. Do you think think that it is possable to record the audio from the phone side with this command in stead of the mic at HS?
            I will give it a try and let you know. I am suprised that no one has done this all ready. oh well we can be the first.
            HS2 Environment
            HomeSeer Way2Call
            Netiom-Xap board
            opnode 1-wire 1.2.7
            Plug-In's
            WeatherXML 1.0.0.32
            mcsTemp V6.2.0.14
            RFXCOM 15.0.0.22
            Odroid X2
            Asterisk 11.5.1
            FreePBX 2.11.0.42
            WebMin 1.720
              Just set your greeting to use message.wav. Via a script have several other customer.wav's be copied over message.wav.
                That would be custom.wav's
