OK, so what is the difference between the command scrip syntax and the vbscript syntax? From what I can tell the command scripts are supposed to be used for IVR and custom answer scripts and vbscript should be used for triggers from HS and such.
I noticed that most of the ivr scripts posted on this board are vbscript though. I did not find anyone posting a command script. So, what is the deal? What is the difference?
Or does it not matter which one you use?
