Discussion for Yamaha RX-V3000 Serial Port control
Script is located at:
http://forums.homeseer.com/showthrea...044#post646044
Description:
Allows commands to be sent and responses monitored using a serial connection to a Yamaha RX-V3000 receiver. Most Yamaha receivers with a serial port can be handled by modifying the commands / repsonses used based on the protocol documents available on the Yamaha site: http://www.yamaha.com/yec/customer/r.../remote_IR.htm
Specifically for the RX-V3000:
standard: http://www.yamaha.com/yec/customer/c...ST_IRCODES.pdf
extended: http://www.yamaha.com/yec/customer/c...000IRCODES.pdf
serial protocols: http://www.yamaha.com/yec/customer/r...mote_RS232.htm
http://www.yamaha.com/yec/customer/codes/RS232C.pdf (includes connector wiring)
All discrete commands work with the exception of setting zone2 volume - still have to volume up or volume down, but it at least provides the level so you know where you are.
I'll attach some screenshots also...
Description:
