New DVD Releases using NetFlix
    I have read all available threads regarding this cool script. I have installed it, and it is downloading images to the "images" folder. However, the asp page displays the following error:
    Script error: Object doesn't support this property or method: 'Server.CreateObject'
    Set fso = Server.CreateObject("Scripting.FileSystemObject")
    Set File = FSO.GetFile(mDirPath & FileFolder)
    If anyone can help me with this I will really appreciate it. This script might actually impress my wife (although I can't be sure). BTW, I am using Homeseer 2.
    Bill
    Did you ever get this working with HS2?
    Also is anyone using it with HS2 or is it not compatable.
      No. I have scaned the forum daily hoping for some news about this script and HS2.
      With my lack of experience with scripting, I am reliant on the efforts of others at this point.
      I did follow a link to the persons site who wrote the script. Looks like he is still happily using HS 1.7 - which I would do if it weren't for remote TTS speaker app (which doesn't work reliably anyway in HS2).
      I am hoping that these scripting gems are not lost forever as a result of the HS2 migration.
      Please let me know if you hear anything,
      Bill
        Okay Will do, This is a great script and I lack scripting knowledge as well.
        Rupp are you reading this? Could you pass your magic wand over it? lol
          You probably just need to change the line to
          Set fso = CreateObject("Scripting.FileSystemObject")
            Tom,
            Sincere thanks...and a hearty round of applause! You made my weekend!
            Now I can give that online rental service a real workout.
            Thanks again,
            Bill
              Tom, that worked.
              thanx
                Mine still doesnt work... Here is my error. I looked at script and I already had that same line other than capatilization differences:
                Script error: Object doesn't support this property or method: 'Server.CreateObject' Set fso = Server.CreateObject("Scripting.FileSystemObject") Set File = FSO.GetFile(mDirPath & FileFolder)
                Could you guys maybe post your revised script to try?
                  pp,
                  I don't think you are not looking far enough down in the script. Open it in notepad or something and look just below the heading
                  "=================Read Text File Contenst==============="
                  There you should find the offending line.
                  Bill
                    I have and see nothing similar. Do I need to add it?
                    ===================== Read Text File Contents ===========================
                    FileFolder = "\html\NewReleases\NewReleases.txt"
                    Set File = FSO.GetFile(FilePath & FileFolder)
                    Set TheFile = File.OpenAsTextStream(OpenFileForReading)
                    Do While theFile.AtEndOfStream <> True
                    count = count + 1
                    ALineOfText = TheFile.ReadLine
                    findlink = instr(ALineOfText,"http://www.netflix.com/MovieDisplay?movieid=")
                    if FindLink <> 0 then ImageIdFound = "yes"
                    Help Please
                      I loaded all the .asp files into TextPad and Searched for the offending line in all files. Some were already the later version, some were not. I switched all occurances across all files to the later and saved all. Then all worked.
                        Smooth, SO I need to search the .asp pages not the main script?
                          Sorry, I searched all the files in the dvds directory. TXT and ASP and HTM files. I backed them up and changed whatever needed change.
                            Yes, Yes... It works. The newreleases.asp and it works woohoo!.
                            Thanks all!
                              I've been wanting this fixed also, THANKS Tom!
                              Terry
