http://mobile.dennehy.net/cgi-bin/skivr.cgi
1 - At the above link, select your location
2 - Now select your ski resort: You will notice there are 3 options for each ski resort: PDA, VR, Code
3 - "VR" will show you the text HS will read when the script is executed
4 - "Code" will give you the "code" to save as a .txt file for HS to exectute. You'll see.
The actual data script is centralized on my server so multiple people can use it without customization. It skims data off the web, so if formatting changes are required in the future they will happen instantaneously for all users without having to change the script at your end.
