Help with scritp error...
    I normally can fix these small errors, but this one seems easy and yet I can't seem to correct it... The following is the statement in error, followed by the full script the statement is included in... This worked up until the latest version of HS2... If you can provide help, I really appreciate it!!!
    Statement in error:
    Text= "<ATT_IGNORE_CASE>" & Mid (page, beginning,length_paragraph) & "</ATT_IGNORE_CASE>"
    Complete Script:
    Sub main()
    Dim d
    Dim m
    Dim dy
    Dim page
    Dim page_name
    Dim length_paragraph
    Dim month_name
    d = Date
    m = Month(d)
    dy = Day(d)
    month_name = MonthName(m)
    If m < 10 Then
    m = 0 & m
    End If
    hs.speak "This day in history!",True
    page_name = m & dy & ".html"
    page = hs.GetURL("http://features.yahoo.com/history/","/" & page_name,True,80)
    beginning = InStr (page, month_name)
    the_end= InStr (page, "Find out what else happened")
    length_paragraph = the_end - beginning
    hs.speak Text,True
    End Sub
    Try putting a msgbox(page) after the second page reference and maybe a msgbox(beginning) etc to make sure the scrape is still finding what you expect. The error is probably caused by missing data.
    -Rupp
      Just had a closer look at the page is returing a 404 error page not found.
      Your page_name is returning 091 and needs to be 0901
      Update $$$$$$$$$$$$$$$$$$$$$$$$$$$
      Here's the working script:
      Sub main()
      Dim d
      Dim m
      Dim dy
      Dim page
      Dim page_name
      Dim month_name
      d = Date
      m = Month(d)
      dy = Day(d)
      if dy < 10 then
      dy = 0 & dy
      end if
      If m < 10 Then
      m = 0 & m
      End If
      Text= "" & Mid (page, beginning,length_paragraph) & ""
      hs.speak Text,True
      End Sub
      -Rupp
        Thanks Rupp... I really appreciate it!
          Your welcome.
          -Rupp
