Scrolling Weather Forcast
    Discussions for the Scrolling Weather forcast in the HomeSeer 2 header.
    Script at:
    http://forums.homeseer.com/showthread.php?t=106808
    Jeff Farmer
    HS 3, HSPhone
    script?
    The directions call for download and running of a script, but there is no script posted.
      Check out first thread at http://board.homeseer.com/showthread.php?t=106769
      Don
        How do you make the clock update and also display the scrolling weather at the same time. As soon as my clock updates, then the message starts over.
        Thanks.
        Billy Draper
          I have another javascript that I wrote that updates the clock. I'll try to post that when I get home tonight. You just add it to the meta.htm file.
          Jeff Farmer
          HS 3, HSPhone
            I've got the one that was posted in another thread. The one I am using looks like it over writes the screen portion where the scrolling weather forecasts is at, thus making it start over again. The clock ticks by just fine but the weather forcast just gets started and then starts over again...
            Billy Draper
              I have mine setup so that both the real time clock and the weather scroll works.
              I'll post it when I get home tonight.
              Jeff Farmer
              HS 3, HSPhone
                Thanks, I'll watch the board tonight.
                Billy Draper
                  Thank you!! Worked like a charm
                  -Mike
                    Thanks a bunch...
                    Billy Draper
                      Can't get this to work correctly. If I edit the weatherxml.js file I can get the message to appear and scroll, but as soo as the weathercom_xml_scroll.txt runs it is blank again. I understad that it is supose to be updating that file so the fack that the message I manually type get earased make sense.
                        Nevermind found the answer here http://board.homeseer.com/showthread.php?t=106769 works great now.
                        thanks
                          Tried and tried. Not working at all.
                          Must have done something silly.
                          Here is what I have-
                          PHP Code:
                          STYLE.CSS =.weatherscroll
                          coloryellow;
                          width300 px;
                          META.HTM = <SCRIPT language="Javascript" src="/weathercom_xml/weatherxml.js"></SCRIPT>
                          script>
                          function
                          displayWeather() {
                          sMessage weatherScroll;
                          userclock.innerHTML=sMessage;
                          userclock.style.display='';
                          userclock.className="weatherscroll";
                          </script
                          Inside this folder-weathercom_xml-there is this file-weatherxml.js-that has this content-weatherScroll ""
                          FB Page - https://www.facebook.com/pages/Capt-Tim/209398425902188
                          HSTouch Layouts - https://www.facebook.com/media/set/?...5902188&type=3
                            Is the file /weathercom_xml/weatherxml.js getting created?
                            Jeff Farmer
                            HS 3, HSPhone
                              Yes it is-
                              Inside this folder-weathercom_xml-there is this file-weatherxml.js-that has this content-weatherScroll = "";
                              Thanx
                              Tim
