Here is a simple script to update hsp address book with the current addresses based on phone numbers received. Once caller id is received, via an event, the script performs a reverse number lookup and then updates the address book based on the information acquired. Directions are within the file and it does work with hs2.
hsp address updater
OK, I partially figured this out.
My Telco passes CID as 1234567890, not 123-456-7890, ot 1-123-456-7890.
The script seemed to be setup for 1-123-456-7890, so I adjusted it so it reads:
Code:area_code = Mid(callnmbr, 1, 3) city_code = Mid(callnmbr, 4, 3) local_code = Mid(callnmbr, 7, 4)
Code:Area_code2 = Mid(callnmbr, 1, 3) City_Code2 = Mid(callnmbr, 4, 3) Local_Code2 = Mid(callnmbr, 7, 4)
Code:newcallnmbr = "1-" & area_code & "-" & city_code & "-" & local_code
Code:newcallnmbr = area_code & "-" & city_code & "-" & local_code
Code:Error~!~Script error in file: Phone_Book_Address_Updater2.txt: 9:Subscript out of range: 'j' in line 122
PHP Code:while spldata(j) <> "map"
Hardware: i5-6400T w/16GB RAM & SSD w/HS3Pro, Z-Net, Harmony Hub x2, Echo Dot x2, Ocelot
Plugins: Z-wave, HSTouch, BLBackup, Harmony, GTS CPUXA, UltraMon3, Nest
HSTouch: Multiple Android Devices; 5 x ToteVision MD-1001 10.1" Win 7 Tablets
Devices: Cooper RF9501 x4, RF9517 x6, RF9534 x1, RF9540-N x7, RF9542 x1, RF9542-Z x2, RFHDSCG x1, RFWC5 x5; Intermatic HA02 x6; FortrezZ MIMOLite x3; Leviton VRPD3-1LW x4, VRR15-1LZ x6; Nest Tstat & 9x Protects; Dragon PD-100 x3, PA-100 x3
