post comments or questions about the hsp address updater script here.
HSP address updater performs a reverse number lookup on all incoming calls (based on caller id) and then updates the address book.
Simple description
1. The address will not be updated if the script finds information already in the address book.
2. It only works with people (Verizon white pages) for now. (business reverse lookups are on another website so I am in the process of writing a version to lookup yellow pages if the number is not found in the white pages)
3. if you like the hs2 popups - it writes to the log/popup what action was performed and why/why not (updated, info not found, etc.)
Directions:
1. copy the script into the script folder
2. create an event that triggers on caller id available and then run the script hsp Address Updater2 and send the parameters ("SendCID", "1") - second parameter is for line number
Simple description
Directions:
