I''ve been getting the following error at regular intervals...
9/20/2005 1:00:48 AM Weather Failed to load XML file
I assume this is from the weatherXML script, but I'm not positive. Everything seems to be working fine with the script, I get the correct forecast in the morning, all the web pages work fine, if I run the event manually it gives no errors. I also have WeatherPLUG installed and it seems to be functioning fine as well. Anyone know what this error is?
Brett
Brett
