my.Elk
  • electron
    2.3 has been posted, check the download link for more information. New features include: arm/disarm, support for monitoring all aspects of all thermostats, improved documentation (much more user friendly now), and much more.
  • electron
    posted 2.0 BETA with some new features.
  • electron
    started a topic my.Elk
    my.Elk
    filename : my.elk.txt
    version : 2.0
    description : Monitor & control the Elk M1 Gold & M1 EZ8 alarm panel
    author : Dan (electron)
    email : dan at marstracker dot org
    changelog:
    • version 2.0 (09292005): *** BETA *** added support for auto syncing: bAutoSync my.Elk can now process ASCII strings sent directly by the elk, using th RAW:COMMAND syntax. See below for more information.
    • version 1.9 (09282005): added the zs command to request zone status updates, internal changes, added support for a complete zone update, which is triggered when issuing the zs command (useful to keep Homeseer in sync with the M1 after a PC reboot
    • version 1.8 (08282005): switched to an INI file, trigger Homeseer events when a keypad button has been pressed
    • version 1.7 (08232005): added the bAutoOpen variable, new keypad_temp function to request a keypad temp reading, and added support for keypad temperature monitoring. Events can be triggered based on temperature by using the "Device Value Change" trigger.
    • version 1.6 (08222005): bug fixes
    • version 1.5 (08112005): added support for monitoring of zones, tasks, voltages and outputs
    • version 1.2 (08102005): added voltage_request
    • version 1.1 (08092005): added user definable settings
    • version 1.0 (08082005): added thermostat_set, customvalue_write, keypad_press, plc_raw, speak_phrase and speak_word
    • version 0.9 (08072005): first release
    commands (descriptions & examples are given in the actual code):
    • display_message
    • plc_on
    • plc_off
    • plc_toggle
    • plc_raw
    • output_on
    • output_off
    • output_toggle
    • speak_phrase
    • speak_word
    • keypad_press
    • customvalue_write
    • thermostat_set
    • keypad_temp
    RAW command supported (example included):
    • speak (raw:speak:this is the phrase to speak)
    • event (raw:event:turn bedroom lights on)
    • device (raw:device:A2n)
    Download (plus updates and comments)
    This script is also compatible with HS 1.x!
