Flash/ASP interface broken, PLEASE HELP!!!
    Rick, can you move this post to the appropriate forum? I posted to quickly and forgot that this forum was for discussion of scripts in the library! Sorry!
    __________________________________________________
    Okay. I run my house off of Audrey's running a modification of the old LCARS interface. It's a simple flash interface that calls an ASP file. It's completely broken in HS2 and I have no clue where to begin fixing it. Please help!
    The flash file uses buttons that have actions like this:
    on (release) {
    action = "alo";
    loadVariablesNum("new.asp", "", "GET");
    This calls an asp file (new.asp) that has something like the following:
    Option Explicit
    sub main()
    dim guestview
    ' To allow guests to view LCARS Data guestview = 1, else = 0
    guestview = 0
    if hs.WebLoggedInUser <> "guest" then
    hs.writelog "LCARS", "Starting LCARS" 'comment out later
    call allowed
    else if guestview = 1 then
    hs.writelog "LCARS", "Guest OK" 'comment out later
    call allowed
    else if guestview = 0 then
    call notallowed
    end if
    end if
    end if
    end sub
    sub allowed()
    dim device_action
    dim action, winamp
    dim volume, stringvolume, ip, SeerAMP
    action = request.QueryString("action")
    ip = Request.ServerVariables("REMOTE_ADDR")
    ' hs.writelog "LCARS", "IP = " & ip
    Set SeerAMP = hs.Plugin("SeerAMP")
    If action = "scheme1" Then
    hs.TriggerEvent "Scheme 1"
    end if
    If action = "triplej" Then
    SeerAMP.WAStop(0)
    SeerAMP.ClearPlaylist(0)
    hs.WaitEvents
    SeerAMP.AddFile 0, "C:\Program Files\Homeseer\seeramp\playlists\triplej.m3u"
    hs.WaitSecs(1)
    SeerAMP.Play(0)
    End If
    If action = "virgin" Then
    SeerAMP.WAStop(0)
    hs.WaitEvents
    SeerAMP.AddFile 0, "C:\Program Files\Homeseer\seeramp\playlists\virgin.m3u"
    hs.WaitSecs(1)
    SeerAMP.Play(0)
    End If
    End Sub
    sub notallowed()
    if hs.WebLoggedInUser = "guest" then
    hs.writelog "LCARS", "Guest Not Allowed"
    end if
    End Sub
    Even the calls within the flash file to load a different movie cause the server to hang, which I don't understand. Sometimes they work, sometimes they don't. Any help is appreciated.
    Brett
    I am intersted in your scripts. Would you share & may be I can help.
      I'm happy to share, especially if I can get some help with this. Do you want the flash files or just the scripts? And how should I get them to you?
      Brett
