Rick, can you move this post to the appropriate forum? I posted to quickly and forgot that this forum was for discussion of scripts in the library! Sorry!
__________________________________________________
Okay. I run my house off of Audrey's running a modification of the old LCARS interface. It's a simple flash interface that calls an ASP file. It's completely broken in HS2 and I have no clue where to begin fixing it. Please help!
The flash file uses buttons that have actions like this:
on (release) {
action = "alo";
loadVariablesNum("new.asp", "", "GET");
This calls an asp file (new.asp) that has something like the following:
Option Explicit
sub main()
dim guestview
' To allow guests to view LCARS Data guestview = 1, else = 0
guestview = 0
if hs.WebLoggedInUser <> "guest" then
hs.writelog "LCARS", "Starting LCARS" 'comment out later
call allowed
else if guestview = 1 then
hs.writelog "LCARS", "Guest OK" 'comment out later
call allowed
else if guestview = 0 then
call notallowed
end if
end if
end if
end sub
sub allowed()
dim device_action
dim action, winamp
dim volume, stringvolume, ip, SeerAMP
action = request.QueryString("action")
ip = Request.ServerVariables("REMOTE_ADDR")
' hs.writelog "LCARS", "IP = " & ip
Set SeerAMP = hs.Plugin("SeerAMP")
If action = "scheme1" Then
hs.TriggerEvent "Scheme 1"
end if
If action = "triplej" Then
SeerAMP.WAStop(0)
SeerAMP.ClearPlaylist(0)
hs.WaitEvents
SeerAMP.AddFile 0, "C:\Program Files\Homeseer\seeramp\playlists\triplej.m3u"
hs.WaitSecs(1)
SeerAMP.Play(0)
End If
If action = "virgin" Then
SeerAMP.WAStop(0)
hs.WaitEvents
SeerAMP.AddFile 0, "C:\Program Files\Homeseer\seeramp\playlists\virgin.m3u"
hs.WaitSecs(1)
SeerAMP.Play(0)
End If
End Sub
sub notallowed()
if hs.WebLoggedInUser = "guest" then
hs.writelog "LCARS", "Guest Not Allowed"
end if
End Sub
Even the calls within the flash file to load a different movie cause the server to hang, which I don't understand. Sometimes they work, sometimes they don't. Any help is appreciated.
Brett
on (release) {
action = "alo";
Option Explicit
sub main()
dim guestview
guestview = 0
call allowed
call allowed
call notallowed
end if
end if
end if
end sub
sub allowed()
dim device_action
dim action, winamp
end if
SeerAMP.WAStop(0)
hs.WaitEvents
hs.WaitSecs(1)
SeerAMP.Play(0)
End If
SeerAMP.WAStop(0)
hs.WaitEvents
hs.WaitSecs(1)
SeerAMP.Play(0)
End If
End Sub
sub notallowed()
end if
End Sub
Brett
