Hello,
I am playing with scripts (vb.Net) to control stuff in HS2. I am a newbie in vb.Net so please be patient with me. I made several scripts so far, but these are pretty much simple scripts.
Because I see now several scripts starting to do the same thing for a different (motion) device I am trying to combine these to one script now and get stuck on how to get access to the EventClass object of HS. But I seem to miss the reference to this object. At least that is what the error tells me.
Basically this is what my script is so far, the red statement is what generates the error. And sorry for the dutch words here and there
Who can tell me what I can do here to move on with the script?
Thanks for any help
Wim
* Later discovery * Oops, it should not have been posted in this forum I think. Sorry for that! Can someone delete this thread, or tell me how to do that?
Imports System.Net Imports System.IO Sub Main(ByVal parm As Object) ' Dit script zal mettertijd alle motion scripts gaan vervangen nu: testversie Dim Code, EventCause, Device Dim DarkEnable, Night, CreateEvent, Aan As Boolean Dim EventRef As Long Dim Ev As Object Dim dv As Object DarkEnable = False Night = False CreateEvent = False Aan = False EventCause = hs.GetLastEvent() EventRef = hs.GetEventRefByName(EventCause) ev = hs.GetEvent(EventRef) For Each dv In ev.ev_devices 'er is slechts één voor een trigger op motion Device = get_device_name(dv.devid) Next Code = hs.GetDeviceCode(Device) If hs.DeviceValueByname("Melders Daytime") = 2 Then Night = True ' if motion is detected switch on that area during night End If If hs.DeviceValueByName("Licht of donker") = 1 Or _ hs.DeviceValueByName("Melders Badkamer Dark") = 0 Then 'licht badkamer staat aan het zal dus wel donker zijn.... Dark = True End If
Thanks for any help
Wim
