Thanks to mycrobytes for providing the original script!
Hi Dan,
I think you would have to give it a try to determine if this method is right for your system. I'm simply using this within my local network as a winamp remote control. I am attaching some of the files I used to get this to work including my personally modified JaniWinamp.vbs. Also, I have found Notepad++ to be very helpful for vbs script editing. I have no official programming training aside from a single university class in java, so I can't answer too many in depth questions about correct syntax etc.
I'm attaching two .txt scripts used to create a PlayPause event and a SendVolume event.
The PlayPause event calls the PlayPause() Sub in JaniWinamp.vbs and is used to act as a Play function, when winamp is stopped (to start from a stopped position) as well as a pause function while winamp is playing (to pause the song).
The SendVolume event is used to send the deviceValue of the device PlayerVolume (renamed from strPlayerVolume from the original) back to winamp only when the device value changes ie. when the slider is moved.
Because of this, you will need to change the Trigger tab under Homeseer Events to be triggered when this device value changes after you install the event.
Also included, are my modified JaniWinamp.vbs script and the startup_x.vbs (with fixes mentioned above).
Let me know if I can be of any more help. Here is a picture of my current GUI.
Ben
Hi Dan,
Ben
