IPCop Firewall Script
    '* Script: IPCop Firewall Status
    '* Purpose: Checks your IPCop firewall for IP Updates and also reports uptime. If a new
    '* IP Address is detected an email is sent in case something needs to be done.
    '* If you are looking for a free firewall, I HIGHLY recommend you check out this
    '* one that I've been using for years with extreme satisfaction:
    '* http://www.ipcop.org/index.php
    '* NOTE: You need to accept your IPCop Firewall's certificate in IE so the script
    '* doesn't get prompted to accept the certificate and wait until someone clicks accept.
    '* Author: Paul Rimmer
    '* $Log: ipcop_firewall_status.txt,v $
    '* Revision 1.5 2005/11/06 19:23:50 paul-rimmer
    '* Remove personal info for posting on Homeseer board
    '* Revision 1.4 2005/11/06 18:39:02 paul-rimmer
    '* Fix comments
    '* Revision 1.3 2005/11/06 18:35:54 paul-rimmer
    '* Update for latest version of IPCop: 1.4.9
    '* Revision 1.2 2002/08/05 00:40:27 paulrimmer
    '* Update devices used for IPCop
    '* Revision 1.1 2002/05/17 18:46:46 paul-rimmer
    '* Initial revision
    Another script I finally tidied up and thought to pass on. Simply setup an event to call this script every 15 min so or so. I use this to remind me to update one of my DNS providers (easyDNS) which isn't automatically handled like others I own (hn.org etc.).
