This is an ASP page that will do a one time speak of a phrase of your choice. It is just a web page that runs it all.
Run the ASP page. On the first run it will create 20 events called VOICE REMINDER 1-20 under the group VOICE REMINDERS if they are not already there.
New for the HS 2.0 setup is the ability to direct the speech to all computers with speaker clients running, just one computer, or just one instance on one computer. Read the botton of that web page for details. Also new is this script will set the Power Fail Recovery for these events.
NOTE: The first load may be a little slow, it is creating an INI file and it is making 20 events. If it takes too long, just refresh the page and it will either load quickly or it will be recreating the missing events.
NOTE: If you already had this going under HS 1.7, please delete all the events under the VOICE REMINDERS event group before running this ASP page the first time.
Just unzip it and put it in your HomeSeer/html directory.
Then run: http://YOUR_HOMESEER_COMPUTER_NAME_HERE/reminders.asp
<O
</O
Changes:
11/8/05 4:00 PM PST -- Fixed error on first installs. (Sorry T.)
11/8/05 5:50 PM PST -- Fixed another error on first installs.
11/12/05 2:15 PM PST -- It looks for changed events only so your log doesn't fill up. That also makes it faster after the initial load.
Future Plans:
Automatic resetting of lines when they are more than two days old.
<O
<O
Changes:
Future Plans:
<O
