I am partially answering my own question below. I changed the service to run as a domain account & everything worked. I don't know why a local system account won't work.
So, at this point everything works with the startSpeakerApp & termSpeakerApp ran as or not as a service.
I posted scripts to the HS2 Script Library for starting & shuting down the Speaker app when HS2 starts & stops. It works OK when HS2 is not ran as a service. But, I get the error shown below when HS2 is ran as a service.
Any thoughts?
The description for Event ID ( 0 ) in Source ( .NET Runtime ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: .NET Runtime version 1.1.4322.2032- Speaker.exe - Common Language Runtime Debugging Services: Application has generated an exception that could not be handled.
Process id=0x17ec (6124), Thread id=0x10e4 (4324).
Click OK to terminate the application.
Click CANCEL to debug the application..
Any thoughts?
