Contacting HomeSeer This Week
See more
See less
Startup Script
  • Startup Script
    Anyone got a basic HS2.0 startup script they would like to share? I upgraded from 1.7.41 and copied my config and scripts directories over and now I get an error from my existing startup script. It is a syntax issue with an if statement but I figured it would be easier toi get a known working script and edit it.
    Kevin,
    The startup.txt file can be blank and usually is unless you desire to do tasks in this file. If you post yours we can help you sort it out or simply comment out the offending lines until you get it working.
    -Rupp
      Thanks, here is the line in the log and the script I use is attached (I hope).
      12/29/2005 9:32:22 PM - Error - Running script, script run or compile error in file: startup.txt1012:Expected 'If' in line 30 More info: Expected 'If'
        Kevin,
        Add end if just above your end sub and it should work just fine. Like this
        end if
        end sub
        -Rupp
          Thanks I figured it was simple -- that did it.
