This is probably elemetary scripting, but I was quite happy with the results.
You can use a basic palmpad remote to control any housecode and devicecode and even run scripts from it. (apologies if this has been gone over before)
The only thing that doesn't work is dimming...
In the example below the Palmpad housecode is set to "P". You can see below how the Event was setup to act on any "P" code received.
Why am I posting this? Well two reasons... one to share and two to get some other ideas on what this can be used for.
Jay
Sub Main Dim JDevice, JAction JDevice = mid(hs.LastX10,3,3) JAction = mid(hs.LastX10,6,1) If JDevice = "P1;" then JDevice = "L1" ' Living Room Fireplace if JDevice = "P2;" then JDevice = "D3" ' Living Room Lamps if JDevice = "P3;" then JDevice = "D1" ' Outside Garage Lights if JDevice = "P4;" then JDevice = "D2" ' Outside Walkway Lights if JDevice = "P5;" then JDevice = "F1" ' Family Room Fireplace if JDevice = "P6;" then JDevice = "F2" ' Curio Cabinet if JDevice = "P7;" then JDevice = "F3" ' China Hutch if JDevice = "P8;" then JDevice = "P8" ' Special - Speak Time/or/Temperture if JDevice = "P9;" then JDevice = "XX" ' Nothing if JDevice = "P10" then JDevice = "XX" ' Nothing if JDevice = "P11" then JDevice = "XX" ' Nothing if JDevice = "P12" then JDevice = "XX" ' Nothing if JDevice = "P13" then JDevice = "XX" ' Nothing if JDevice = "P14" then JDevice = "XX" ' Nothing if JDevice = "P15" then JDevice = "XX" ' Nothing if JDevice = "P16" then JDevice = "XX" ' Nothing if JDevice = "XX" then Exit Sub 'hs.writelog "Debug", "JDevice=" & JDevice & " - JAction=" & JAction '===Check for Special action keys here=== if JDevice = "P8" and JAction = "2" then hs.Run "pRemoteSpeakTime.txt" hs.writelog "Palm", "pRemoteSpeakTime script activation" exit sub end if if JDevice = "P8" and JAction = "3" then hs.Run "pRemoteSpeakTemp.txt" hs.writelog "Palm", "pRemoteSpeakTemp script activation" exit sub end if '===End check for Special action Keys=== If JAction = "2" then JAction = "on" if JAction = "3" then JAction = "off" hs.ExecX10 JDevice, JAction, 0, 0 hs.writelog "Palm", JDevice & " " & JAction End Sub
Jay
