This is probably elemetary scripting, but I was quite happy with the results.
You can use a basic palmpad remote to control any housecode and devicecode and even run scripts from it. (apologies if this has been gone over before)
The only thing that doesn't work is dimming...
In the example below the Palmpad housecode is set to "P". You can see below how the Event was setup to act on any "P" code received.
 Sub Main
 Dim JDevice, JAction
 JDevice = mid(hs.LastX10,3,3)
 JAction = mid(hs.LastX10,6,1)
 If JDevice = "P1;" then JDevice = "L1" ' Living Room Fireplace
 if JDevice = "P2;" then JDevice = "D3" ' Living Room Lamps
 if JDevice = "P3;" then JDevice = "D1" ' Outside Garage Lights
 if JDevice = "P4;" then JDevice = "D2" ' Outside Walkway Lights
 if JDevice = "P5;" then JDevice = "F1" ' Family Room Fireplace
 if JDevice = "P6;" then JDevice = "F2" ' Curio Cabinet
 if JDevice = "P7;" then JDevice = "F3" ' China Hutch
 if JDevice = "P8;" then JDevice = "P8" ' Special - Speak Time/or/Temperture
 if JDevice = "P9;" then JDevice = "XX" ' Nothing
 if JDevice = "P10" then JDevice = "XX" ' Nothing
 if JDevice = "P11" then JDevice = "XX" ' Nothing
 if JDevice = "P12" then JDevice = "XX" ' Nothing
 if JDevice = "P13" then JDevice = "XX" ' Nothing
 if JDevice = "P14" then JDevice = "XX" ' Nothing
 if JDevice = "P15" then JDevice = "XX" ' Nothing
 if JDevice = "P16" then JDevice = "XX" ' Nothing
 if JDevice = "XX" then Exit Sub
 'hs.writelog "Debug", "JDevice=" & JDevice & " - JAction=" & JAction
 '===Check for Special action keys here===
 if JDevice = "P8" and JAction = "2" then
 	hs.Run "pRemoteSpeakTime.txt"
 	hs.writelog "Palm", "pRemoteSpeakTime script activation"
 	exit sub
 end if
 if JDevice = "P8" and JAction = "3" then
 	hs.Run "pRemoteSpeakTemp.txt"
 	hs.writelog "Palm", "pRemoteSpeakTemp script activation"
 	exit sub
 end if
 '===End check for Special action Keys===
 If JAction = "2" then JAction = "on"
 if JAction = "3" then JAction = "off"
 hs.ExecX10 JDevice, JAction, 0, 0
 hs.writelog "Palm", JDevice & " " & JAction
 End Sub
Why am I posting this? Well two reasons... one to share and two to get some other ideas on what this can be used for.
Jay
