I have a script that creates an event using the NewTimeEvent command.
hs.NewTimeEvent en,tm, td, 1, 1, 1, 1, 1, 1, 1, "dv
ff", 1, dv & "-NoMotion.txt",eg
This is working fine, however I would like to eliminate the need to specify a script and instead put into the event itself the commands that are currently in the script.
I think I can do this because there are fields in the Actions List to do it if I'm manually editing the event.
Question is, how do I do it programatically? I do not see anything in the Event Class tor elsewhere hat accesses the appropriate properties.
Suggestions?
Frank
Suggestions?
Frank
