1.Need help with: a recurring event
    Hello,
    I know nothing about scipting and so I hope I found someone who want help me.
    I set up a device (Secu16 supervised Input..) which is controling a waterventil.
    Now I want a event that fires after a time the device is changing to "off" ( about 30 minutes ) and again and again until this device going back to "on".
    I tried to do this with a event- condition "is off for exactly 30 min" but then the event fires only once after those 30 min.
    How can I do this right ?
    Eric
    Try "has been OFF for at least 30 minutes" See attached drop down list.
    Billy Draper
      Hello Billy,
      thanks, but with this condition the event runs after 30 min. every second, because each time is then longer than 30 min.
      I tried that.
      Eric
        Try setting the cannot retrigger for X number of seconds... See attached.
        Billy Draper
          Hi,
          I try this for the moment and it seems to work.
          Have to test some other things with that and will report later this day.
          Thank you
          Eric
            Great, you could also bump up the 60 seconds to a higher number if you need too...
            Billy Draper
              Hi, I am back.
              It works perfect.
              Thank you a lot.
              Eric
