1.Need help with: a recurring event
  • eaba
    Hi, I am back.
    It works perfect.
    Thank you a lot.
    Eric
  • bdraper
    Great, you could also bump up the 60 seconds to a higher number if you need too...
  • eaba
    I try this for the moment and it seems to work.
    Have to test some other things with that and will report later this day.
    Thank you
    Eric
  • bdraper
    Try setting the cannot retrigger for X number of seconds... See attached.
  • eaba
    Hello Billy,
    thanks, but with this condition the event runs after 30 min. every second, because each time is then longer than 30 min.
    I tried that.
    Eric
  • bdraper
    Try "has been OFF for at least 30 minutes" See attached drop down list.
  • eaba
    started a topic 1.Need help with: a recurring event
    Hello,
    I know nothing about scipting and so I hope I found someone who want help me.
    I set up a device (Secu16 supervised Input..) which is controling a waterventil.
    Now I want a event that fires after a time the device is changing to "off" ( about 30 minutes ) and again and again until this device going back to "on".
    I tried to do this with a event- condition "is off for exactly 30 min" but then the event fires only once after those 30 min.
    How can I do this right ?
    Eric
