2.Need help with: speak by receive any X-10 signal
  • 2.Need help with: speak by receive any X-10 signal
    Hello, how can I set up an event that fires if HS is receiving a x-10 signal (any signal )?
    In the Trigger section I can only set one specific house and device code.
    I need to fire this event as HS receive any X-10 code.
    Or maybe better: Can I made a list of codes therefore ?
    I not want to set up this event multiple for each code apart.
    Eric
    If you are using HS2, just set the trigger to "Received X10".
    On the command pull down, just select "Any X10"
    Ignore the house and unit code.
    Jon
      Hi, thank you.
      Yes, I am on HS 2.
      Just tried this, but it doesn't work.
      I choose triggering by "receive x-10" leave the housecode on "A 1 " and set " Any X10".
      Eric
        Your right! - never tried it so assumed
        Looks like you can only trigger all on an individual house letter code. This would mean setting up 16 events for all 16 letters.
        It's done the same way but choose your house letter code and set the unit code to 'Any'
        Jon
          Yeah, thanks a lot.
          Thats one way.
          I'll do this for the moment.
          But:
          Can I also do this with a script and maybe exclude same X-10 codes such as my motion sensor "A15" ?
          Eric
            Yes, but the script still needs to be triggered by an event.
            If your actions are scriptable then you would just put a check at the beginning of the script using hs.LastX10 to detect the house code sent. If this matches (e.g A15) then it would just exit the script without taking any action.
            Jon
              Sorry, but I know nothing about scripting yet.
              Can you give me an example how I can do this, please.
              I was thinking this script can run always and listen to all x-10 signals and then execute an event.
              Eric
                Scripts cannot listen. They have to be executed by an event or some other means and then act on the information they have at that time.
                It could be done but very inefficient and not recommended.
                You would have to set-up a recurring event every second to trigger the script and then check for X10 activity.
                It would be much easier if you just set up the 16 events as described earlier but get this to run a script to check the last X10 activity and then run the event you want if the House code or House codes are not excluded:
                Example:
                PHP Code:
                Sub main()
                Dim strLast
                Dim strEvent
                strLast
                =hs.LastX10
                If Instr(strLast,"A15"then Exit sub
                If Instr(strLast,"C10"then Exit sub
                strEvent
                =hs.TriggerEvent ("Name of your event you wish to trigger")
                end sub
                In this example, when the script is triggered by an X10 code, it will trigger the event apart from a house code A15 or C10
                Jon
                  Ooh,
                  ok that I was n`t knowing.
                  Than it is in dead better that I use those 16 events apart.
                  But if I set a global event with a trigger "A" "All X-10" and I will exclude this "A 15" ?
                  How I do that without setting up 15 events from A-1 to A-14 and A-16 ?
                  Eric
                    Could you use something like this?
                    PHP Code:
                    sub main()
                    dim icount
                      icount
                    0
                    for 1 to 16    'Unit codes
                        for j = 65 to 80    '
                    ascii codes for A through P
                    If hs.DeviceExists(chr(j)&i) <> -1 then
                    If hs.IsOn(chr(j)&i) = True then
                                    icount
                    icount 1
                                End
                    if
                    End if
                    Next
                      Next
                    ' hs.WriteLog Counter,"THERE ARE " &   icount   &   "  DEVICES IN THE ON STATE"
                      hs.SetDeviceString "z99", "THERE ARE " & iCount & " DEVICES IN THE ON STATE"
                    End sub
                    Don't remember who wrote for me now
                    Tim
                    FB Page - https://www.facebook.com/pages/Capt-Tim/209398425902188
                    HSTouch Layouts - https://www.facebook.com/media/set/?...5902188&type=3
                    “No, I’m from Iowa. I only work in outer space.” – Captain Kirk
