I can't use the MediaPlay command with URLs
    Hi,
    I want to hear radios from Internet using these two commands:
    hs.mediafilename = "mms://200.59.146.10/radioblue-ba"
    hs.mediaplay
    And I receive the following message in the Log:
    Error Playing media on Media Player, File 'mms://200.59.146.10/radioblue-ba' not found.
    I tested with a simple wav file located in the same computer where HS is running:
    hs.mediafilename = "C:\Archivos de programa\HomeSeer 2\wave\PPA.wav"
    hs.mediaplay
    and it's working fine.
    I made another test with a wav file comming from an URL:
    hs.mediafilename = "http://212.8.184.250/realspeak/files/geyjezgl.wav"
    hs.mediaplay
    And I receive another error in the Log file:
    Error Playing media on Media Player, File 'http://212.8.184.250/realspeak/files/geyjezgl.wav' not found.
    It's seems to be that mediafilename doesn't support URLs although in the documentations says clearly: "This function sets the file name or URL that is to played using the Windows media player."
    Please let me know if this is an error in the documentation, a bug in HS, or something that I'm doing wrong.
    I'm using HS 2.0.2041.0
    Thanks in Advance,
    I would file a help ticket on this.
    -Rupp
      Thanks Rupp... Let me know when it is fixed.
        I was asking you to open up a help request.
        -Rupp
          How Rupp?... I never did this... Could you help me on this procedure?
            The best way is to select Help > System Information and at the bottom of the page is a link Create A New Helpdesk Ticket and Add This Information. Select this and add your problem description.
            -Rupp
              Rupp, Just to update you on this to close the loop. Today I receive an answer from the Homeseer's Help Desk. The complete answer was:
              "Sorry for the confusion but the documentation is indeed in error. The hs.Mediaxxx functions are designed to work with media on your local computers. The Windows Media Player plug-in for HomeSeer does have a PlayURL command and does support what you want to do. I will update the documentation to correct this."
              As you can see there is not a bug and there is an error in the documentation.
              Thanks for your help.
                Thanks. I saw where Rick had replied to that ticket.
                -Rupp
